Home » Modeling » GMF (Graphical Modeling Framework) » Textual Modelling inside GMF
Textual Modelling inside GMF [message #121145] Mon, 23 April 2007 05:07
Originally posted by: sadilek.informatik.hu-berlin.de
Hello everybody,
do you know of any project that integrates a textual editor with syntax
highlighting, error support and code completion into GMF?
Background:
I am building a DSL that contains a sublanguage for expressions. I don't
want to have a graphical editor for the expressions but a textual editor
that hovers up when I click on an expression object in the GMF-generated
graphical editor. When saving the diagram file, the expression should be
parsed and appropriate model elements should be generated so that the
expression is visible in the generic EMF-tree editor both as plain
string value and also as parsed model elements.
Solution proposal:
I thought about integrating xText from openArchitectureWare into GMF.
This seems to be a non-trivial task, so I thought I ask for existing
solutions before beginning ;)
Best regards
Daniel Sadilek
Previous Topic:Reading diagram informations using GMF API
Next Topic:how can i acess the content of other editor
Current Time: Wed Sep 03 07:08:38 EDT 2025
Powered by FUDForum. Page generated in 0.05440 seconds
