Home » Eclipse Projects » Equinox » p2 works... the second time
p2 works... the second time [message #120751] Wed, 05 November 2008 13:50
(Apologies for cross-posting. I only found out about the equinox
newsgroup after I sent the first message to the platform newsgroup :( )
I'm encountering some strange behaviour in p2 (using the 3.4.1 Modeling
distribution). For some update sites the following happens:
- I add an update site
- I select the check box next to it
- I press install
- The "Calculating requirements and dependencies" windows pops up
- It takes quite some time to fill the progress bar
- While the progress bar is being filled the check-boxes next to the
features of the update site are unticked (!!!)
- The Install window pops up with nothing in the list so I have to press
cancel
- I re-select the features under the update site, press install again
and then it works
(For example this happens with
http://download.eclipse.org/modeling/gmt/epsilon/updates/ which I'm
maintaining).
Anyone seen this before? Any idea what I may be doing wrong?
Dimtiris
Previous Topic:Equinox command line vs Equinox Eclipse - Classpath issues.
Next Topic:Tale of Two Equini, Inside vs Outside eclipse
Current Time: Tue Jun 10 05:33:02 EDT 2025
Powered by FUDForum. Page generated in 0.05501 seconds
