Home » Eclipse Projects » Remote Application Platform (RAP) » Equinox - Jetty - Rap - Default Page - Index.html
Equinox - Jetty - Rap - Default Page - Index.html [message #117603] Tue, 06 January 2009 07:37 Go to next message
How can I configure equinox to load default" index.html" when
http://<domainname> is provided.
I tried using the latest rap from CVS Head and I get the following page for
http://localhost
<classpath>
<classpathentry kind="con" path="org.eclipse.pde.core.requiredPlugins"/>
<classpathentry kind="src" path="src"/>
<classpathentry kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
<classpathentry kind="output" path="bin"/>
</classpath>
instead of loading index.html
- Walter.
Re: Equinox - Jetty - Rap - Default Page - Index.html [message #117615 is a reply to message #117603] Tue, 06 January 2009 07:39 Go to previous messageGo to next message
My plugin.conf has the following entry
<extension point="org.eclipse.equinox.http.registry.resources">
<resource
alias="/"
base-name="/">
</resource>
</extension>
"Walter Prabhakar" <kwchess@gmail.com> wrote in message
news:gjvj87$7s5$1@build.eclipse.org...
> for http://localhost
> <classpath>
> </classpath>
> - Walter.
Re: Equinox - Jetty - Rap - Default Page - Index.html [message #117834 is a reply to message #117615] Wed, 07 January 2009 09:03 Go to previous messageGo to next message
As a work around, I had copied index.html to ".aindex.html"
Looks like the first file in the bundle is shown.
By adding (dot)index.html I am able to achieve what I needed.
- Walter
news:gjvjbl$872$1@build.eclipse.org...
> <resource
> alias="/"
> base-name="/">
> </resource>
> </extension>
>> <?xml version="1.0" encoding="UTF-8"?>
>> <classpath>
>> </classpath>
>> - Walter.
Re: Equinox - Jetty - Rap - Default Page - Index.html [message #118156 is a reply to message #117834] Fri, 09 January 2009 20:13 Go to previous messageGo to next message
Bad News. Works only within Eclipse IDE not outside.... Any work around ?
- Walter.
news:gk2ck5$kmf$1@build.eclipse.org...
> - Walter
>> <resource
>> alias="/"
>> base-name="/">
>> </resource>
>> </extension>
>>> <classpath>
>>> </classpath>
>>> - Walter.
Re: [Solved] Equinox - Jetty - Rap - Default Page - Index.html [message #118501 is a reply to message #118156] Thu, 15 January 2009 09:09 Go to previous message
More info @
http://www.eclipse.org/newsportal/article.php?id=5720&gr oup=eclipse.technology.equinox#5720
- Walter
news:gk8sko$pqh$1@build.eclipse.org...
> - Walter.
>> - Walter
>>> <resource
>>> alias="/"
>>> base-name="/">
>>> </resource>
>>> </extension>
>>>> <classpath>
>>>> </classpath>
>>>> - Walter.
Previous Topic:Store Initial Parameters from web.xml
Next Topic:observe when user hit the browser refresh button
Current Time: Fri Jul 25 08:32:44 EDT 2025
Powered by FUDForum. Page generated in 0.06921 seconds
