Engine logger [message #117518] |
Thu, 26 January 2006 09:04  |
Originally posted by: jan.tanis.coas.com
Hi All,
I've adjusted the example java class that calls the report engine, but i
noticed that it logs loads of information. Is there a way to avoid this
logging in a "quite" way, or actually *NONE* logging. How do I disable
logging from the engine?
Thanks, Jan.
Re: Engine logger [message #118446 is a reply to message #117711] |
Fri, 27 January 2006 03:46  |
Thanks Stanley,
That works just fine :)
Best regards, Jan.
Stanley Wang wrote:
> Jan Tanis wrote:
>> Hi All,
>> i noticed that it logs loads of information. Is there a way to avoid
>> this logging in a "quite" way, or actually *NONE* logging. How do I
>> disable logging from the engine?
>> Thanks, Jan.
> Check out EngineConfig.setLogConfig() function.
> public void setLogConfig(String directoryName, Level level)
> Level is a class defined by java.util.logging package.
> Stanley Wang
> BIRT Engine
FUDForum. Page generated in 0.04202 seconds
