Home » Eclipse Projects » GEF » which version to use with the last integration build of eclipse
which version to use with the last integration build of eclipse [message #115674] Wed, 04 February 2004 14:56 Go to next message
Originally posted by: emerson.tre-sc.gov.br
I tried to install the last integration build of GEF with the last
integration build of eclipse. I expand the GEF at eclipse root dir, but it
doens't show any restart warning at eclipse startup, as it used to be.
And when I tried to install a plugin that needs GEF it says that I doens't
have GEF installed:
"The bundle com.bonevich.eclipse.cvsgrapher [85] could not be resolved.
Reason: missing required bundle org.eclipse.gef,required bundle
org.eclipse.draw2d"
Any clues?
Re: which version to use with the last integration build of eclipse [message #115730 is a reply to message #115674] Wed, 04 February 2004 18:49 Go to previous messageGo to next message
The latest integration build of GEF doesn't work with the latest Integration
build of Eclipse. You may want to try the latest from CVS, wait for the next
Integration build, or add org.eclipse.core.runtime.compatibility as a
required plugin to the GEF plugin.xml.
"Emerson Cargnin" <emerson@tre-sc.gov.br> wrote in message
news:bvripv$gij$1@eclipse.org...
> have GEF installed:
> org.eclipse.draw2d"
> Any clues?
Re: which version to use with the last integration build of eclipse [message #115950 is a reply to message #115730] Thu, 05 February 2004 10:51 Go to previous messageGo to next message
Didn't work...
I changed : plugins/org.eclipse.gef_3.0.0/plugin.xml
<import plugin="org.eclipse.osgi"/>
<added> <import plugin="org.eclipse.core.runtime.compatibility"/>
</requires>
But it gives any different sign...
> > have GEF installed:
> > org.eclipse.draw2d"
> > Any clues?
Re: which version to use with the last integration build of eclipse [message #115985 is a reply to message #115950] Thu, 05 February 2004 11:10 Go to previous messageGo to next message
Have you checked to see if the GEF and Draw2d plugins show up in the
Help->About Eclipse Platform->Plug-in Details page?
If they are not there, try going to Help->Software Updates->Manage
Configuration. Right click on Eclipse Platform, and click on Detected
changes.. GEF should be there, and you can click "Finish" to complete the
installation.
news:bvtopq$t24$1@eclipse.org...
> Didn't work...
> </requires>
Integration
next
but it
doens't
> > > have GEF installed:
resolved.
> > > org.eclipse.draw2d"
> > > Any clues?
Re: which version to use with the last integration build of eclipse [message #116012 is a reply to message #115985] Thu, 05 February 2004 14:13 Go to previous message
Now it worked.
In some versions ago, eclipse itserlf asked for a restart when finding an
detected change.
And there was an easier option directly at the help menu to detect changes
Maybe this option should be put back :P
Thanks!!!
> installation.
> > Didn't work...
> > </requires>
> Integration
> next
> but it
> doens't
> > > > have GEF installed:
> resolved.
> > > > org.eclipse.draw2d"
> > > > Any clues?
Previous Topic:GEF I20040205 and Logic Example from CVS?
Next Topic:[JOB] Contract GEF developer opportunity
Current Time: Fri Sep 19 05:22:11 EDT 2025
Powered by FUDForum. Page generated in 0.11035 seconds
