Home » Language IDEs » C / C++ IDE (CDT) » How can I permanently set the MinGW path in "Run"?
How can I permanently set the MinGW path in "Run"? [message #1145774] Sat, 19 October 2013 15:40 Go to next message
whenever I try to run a program, it doesn't work until I manually add a PATH to my MinGW\bin folder in the Environment tab of Run Config.
I have to do this whenever I start a new project.
Is there a way to globally set the Path for all projects?
Thanks in advance.
Re: How can I permanently set the MinGW path in "Run"? [message #1152578 is a reply to message #1145774] Thu, 24 October 2013 00:04 Go to previous message
Have you tried adding MinGW\bin to your PATH environment variable? (Then restarting Eclipse)
Previous Topic:ctrl + H stopped working in my Mac
Next Topic:How to add path for Code Analysis
Current Time: Sat Jun 14 10:51:32 EDT 2025
Powered by FUDForum. Page generated in 0.03414 seconds
