Home » Eclipse Projects » GEF » reloading the model
reloading the model [message #114863] Fri, 30 January 2004 08:46 Go to next message
Originally posted by: nospam.gmx.net
Hi GEFfers!
Sometimes i encounter Exceptions in myGEF Editor which are deep inside the
Draw2d framework.
(e.g. LinkFigure has no parent layer, AbstractEditpart.getRoot returns
null ).
I assume that happens because in some situations, i reload the model
and with the Editor#setContents() method.
What is the best way to clean up the editor in order to rebuild the Diagram?
Regards, Ingo
Re: reloading the model [message #114878 is a reply to message #114863] Fri, 30 January 2004 09:47 Go to previous messageGo to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Ingo Koch wrote:
| Hi GEFfers!
| Draw2d framework.
| null ).
Diagram?
| Regards, Ingo
have you tried refresh on editparts?
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAGm5oVbJM14DSCi0RAvEwAJ9JZeeCsyaoSOGBae7PoJPABq4s2QCg k9LU
JkSDIPwLpse4DOoLlyUdRVk=
=heHq
-----END PGP SIGNATURE-----
Re: reloading the model [message #114956 is a reply to message #114863] Fri, 30 January 2004 11:20 Go to previous messageGo to next message
AFAIK the editparts should always be in sync with the model. If you are
reloading the model because of resource change event then setContents should
work fine.
"Ingo Koch" <nospam@gmx.net> wrote in message
news:bvdn36$gb1$1@eclipse.org...
> Hi GEFfers!
> Draw2d framework.
> null ).
Diagram?
> Regards, Ingo
Re: reloading the model [message #115095 is a reply to message #114956] Mon, 02 February 2004 04:41 Go to previous message
Hello Randy,
i found the bug which caused these strange error (model created a link with
no target, which , on reload called a deactivateFigure() where there was no
figure ).
But now I
Previous Topic:Extending the Rulers
Next Topic:DND
Current Time: Thu Nov 13 06:37:24 EST 2025
Powered by FUDForum. Page generated in 0.03921 seconds
