Home » Eclipse Projects » Equinox » IInstallFeatureOperation vs. P2
IInstallFeatureOperation vs. P2 [message #114034] Sat, 12 July 2008 08:45 Go to next message
Hi all,
I'm developing an RCP application where I need to install, update and
uninstall some features programmatically. Right now I'm using the
org.eclipse.update.operations.OperationManager to create my install,
update and uninstall operations.
As Eclipse Ganymede offers P2 to handle updates/installs I wonder if
there are examples how to perform the same commands using p2. Is this
possible and how complicated will this be?
After spending hours and hours with the P2 UI code I still haven't got an
idea how it really works. As I've already spent a lot of time to solve
this issue I would be very grateful for any advise.
Eugen
Re: IInstallFeatureOperation vs. P2 [message #114540 is a reply to message #114034] Fri, 18 July 2008 14:38 Go to previous message
In p2 the model is different, you create a request (ProfileChangeRequest)
that first gets resolved and eventually gets executed. The code in
ProvisioningHelper.install() shows this. If you want you can probably
directly use it.
Please take a look at the class ProvisioningHelper
"Eugen Reiswich" <reiswich@gmx.de> wrote in message
news:20cf0640f805ffd6c60cd7e4465b5392$1@www.eclipse.org...
> Hi all,
> Regards,
> Eugen
Previous Topic:Separating config.ini and osgi cache.
Next Topic:[p2] Director install: artifact file for com.ibm.icu noot found
Current Time: Tue Jun 17 11:46:12 EDT 2025
Powered by FUDForum. Page generated in 0.03231 seconds
