Home » Archived » Visual Editor (VE) » Custom SWT-Widget added but not drawn
Custom SWT-Widget added but not drawn [message #113366] |
Thu, 15 December 2005 17:27  |
I have a set of custom SWT-Widget which e.g. derived from Text,
DropDown, ... . I can select them and drag them to the composite, they
are added to the code but are not drawn on the screen.
Do my widget have to implement something special to be drawn in VE, some
sort of interface or the like?
Tom
Re: Custom SWT-Widget added but not drawn [message #113955 is a reply to message #113943] |
Thu, 22 December 2005 09:23   |
Hi Tom,
VE 1.1 is based on Eclipse 3.1 and things might not work with Eclipse
3.2M3. It would be great if you could upgrade to VE 1.2M1 and Eclipse
3.2M4 as you get new features and bug fixes.
Sri.
Tom Schindl wrote:
> Hi Sri,
> if you mean in .metadata/.log. No there's no message at all. I read the
> article about extending VE and gave it a try creating a plugin and
> adding the desired dependencies but no change.
> I'm using eclipse3.2-M3 and VE 1.1.0 which I installed using the update
> manager. Should I upgrade to eclipse M4 and VE 1.2M1?
> Tom
> Sri Gunturi wrote:
>>Hi Tom,
>> Which platform is this happening in? Also are there any exceptions
>>in the .log file?
>>Regards,
>>Sri.
>>Tom Schindl wrote:
>>>Hi,
>>>Tom
Re: Custom SWT-Widget added but not drawn [message #113968 is a reply to message #113955] |
Thu, 22 December 2005 11:57   |
well did the upgrade and now I can use my own widgets in the VE which is
really cool. The problem I have faced is that my widget have to placed
on a special Composite implementing an interface else they throw an
IllegalArgumentException and I have forgotten todo so. Why are
exceptions not displayed in the error-log?
I will now take a look at the Properties dialog and how I could pass my
own special properties. We have implemented a SWT/JFace-DB-Binding now
we are trying to create a visual designer for Database-Forms.
At the moment I have the following structure:
- FormComposite extends Composite
- DatabaseModel
- TextField extends Text
- CurrencyField extends TextField
- DropDown extends Combo
- FormComposite extends TableViewer
- TextColumn extends TableColumn
- CurrencyColumn extends TableColumn
What I'd like to do is the following:
- User has a View-Containing it's datasources using the DTP-Project
- User selects one of the queries and drags them to the FormComposite
=> DatabaseModel is created with selected query
=> DatabaseModel is assigned to FormComposite
- User selects one of fields returned by the query and drags it to the
form-composite (based on the column type a TextField, CurrencyField,
...) is created on the FormComposite
Now different Questions arise to me:
- Does VE provide any hooks to register when the user drags things from
the DTP-View in the VE area and decide what has to be added?
- Is it possible "design components" who are JavaBeans but don't are not
displayable like Text, Composite - my case e.g. the DatabaseModel
- Is it possible to use JFace-Components like TableViewer, TreeViewer in
VE.
One more thing:
I read the article about extending VE but I ask my self if it's really
true because it says one has to create a plugin, add dependency like
gef, ... which was not necessary for me.
Tom
Sri Gunturi wrote:
> Hi Tom,
> Eclipse 3.2M3. It would be great if you could upgrade to VE 1.2M1 and
> Eclipse 3.2M4 as you get new features and bug fixes.
> Regards,
> Sri.
> Tom Schindl wrote:
>> Hi Sri,
>> Tom
>> Sri Gunturi wrote:
>>> Hi Tom,
>>> in the .log file?
>>> Regards,
>>> Sri.
>>> Tom Schindl wrote:
>>>> Hi,
>>>> some
>>>> Tom
Re: Custom SWT-Widget added but not drawn [message #113980 is a reply to message #113968] |
Thu, 22 December 2005 12:27   |
Hi Tom,
> Why are exceptions not displayed in the error-log?
If you have a development environment, in the launch configuration goto
the Tracing tab and enable tracing. Then check the
'org.eclipse.jem.proxy' plugin and check the 'remote/debug/vmtraceout'
option to see the remote VM's output.
> things from the DTP-View in the VE area and decide what has
> to be added?
Currently the default behavior of the widgets in VE have not had a
requirement for such a drag&drop scenario from other views. You can
implement such a feature by creating your own 'drag&drop' aware widgets
and corresponding EditParts/EditPolicies. Please have a look at the
"Extending the Visual Editor Tutorial: Enabling support for a custom
widget" tutorial for that.
> are not displayable like Text, Composite - my case e.g. the
> DatabaseModel
Yes. Drop using the ChooseBean entry in palette the java.awt.print.Book
class on VE. It is a non-visual which shows up as a bean. I guess you
want to put a fancy EditPart for your DatabaseModel class. Again that
can be achieved, and instructions are in the tutorial mentioned above.
> TreeViewer in VE.
Actually VE 1.2M1 now has support added for JFace Viewers
(TreeViewer/TableViewer/ComboViewer). Please have a look at the New &
Noteworthy about them:
http://www.eclipse.org/vep/WebContent/docs/newAndNoteworthy/ 1.2-M1/
> really true because it says one has to create a plugin, add
> dependency like gef, ... which was not necessary for me.
If you want to extend the functionality of VE which exists in Eclipse,
you would have to make your own plugin for Eclipse. So that when Eclipse
loads it adds your own extensions on top of whats already there. So, you
would have to create a plugin as mentioned in the tutorial, to do all
the cool stuff you mentioned above.
Hope that helped.
Sri.
Tom Schindl wrote:
> - DatabaseModel
> VE.
> One more thing:
> Thanks
> Tom
> Sri Gunturi wrote:
>>Hi Tom,
>>Regards,
>>Sri.
>>Tom Schindl wrote:
>>>Hi Sri,
>>>Tom
>>>Sri Gunturi wrote:
>>>>Hi Tom,
>>>>in the .log file?
>>>>Regards,
>>>>Sri.
>>>>Tom Schindl wrote:
>>>>>Hi,
>>>>>some
>>>>>Tom
Re: Custom SWT-Widget added but not drawn [message #114006 is a reply to message #113968] |
Thu, 22 December 2005 13:40   |
Hi Tom,
Since you are doing some binding from visual components to data, I
thought you might be interested in using the JFace binding currently
being developed. Dr.Gili Mendel has created a presentation on how to
achieve this using the new JFace bindings available in 3.2M4 builds. You
can view this presentation at
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-ui-home/databinding-proposal/Viewlets/Binders1_viewlet. html
Sri.
Tom Schindl wrote:
> - DatabaseModel
> VE.
> One more thing:
> Thanks
> Tom
> Sri Gunturi wrote:
>>Hi Tom,
>>Regards,
>>Sri.
>>Tom Schindl wrote:
>>>Hi Sri,
>>>Tom
>>>Sri Gunturi wrote:
>>>>Hi Tom,
>>>>in the .log file?
>>>>Regards,
>>>>Sri.
>>>>Tom Schindl wrote:
>>>>>Hi,
>>>>>some
>>>>>Tom
Re: Custom SWT-Widget added but not drawn [message #611687 is a reply to message #113943] |
Hi Tom,
Sri.
Tom Schindl wrote:
> Hi Sri,
> Tom
> Sri Gunturi wrote:
>>Hi Tom,
>>in the .log file?
>>Regards,
>>Sri.
>>Tom Schindl wrote:
>>>Hi,
>>>Tom
Re: Custom SWT-Widget added but not drawn [message #611688 is a reply to message #113955] |
- DatabaseModel
VE.
One more thing:
Tom
Sri Gunturi wrote:
> Hi Tom,
> Regards,
> Sri.
> Tom Schindl wrote:
>> Hi Sri,
>> Tom
>> Sri Gunturi wrote:
>>> Hi Tom,
>>> in the .log file?
>>> Regards,
>>> Sri.
>>> Tom Schindl wrote:
>>>> Hi,
>>>> some
>>>> Tom
Re: Custom SWT-Widget added but not drawn [message #611689 is a reply to message #113968] |
Hi Tom,
> to be added?
> DatabaseModel
> TreeViewer in VE.
Hope that helped.
Sri.
Tom Schindl wrote:
> - DatabaseModel
> VE.
> One more thing:
> Thanks
> Tom
> Sri Gunturi wrote:
>>Hi Tom,
>>Regards,
>>Sri.
>>Tom Schindl wrote:
>>>Hi Sri,
>>>Tom
>>>Sri Gunturi wrote:
>>>>Hi Tom,
>>>>in the .log file?
>>>>Regards,
>>>>Sri.
>>>>Tom Schindl wrote:
>>>>>Hi,
>>>>>some
>>>>>Tom
Re: Custom SWT-Widget added but not drawn [message #611691 is a reply to message #113968] |
Hi Tom,
Sri.
Tom Schindl wrote:
> - DatabaseModel
> VE.
> One more thing:
> Thanks
> Tom
> Sri Gunturi wrote:
>>Hi Tom,
>>Regards,
>>Sri.
>>Tom Schindl wrote:
>>>Hi Sri,
>>>Tom
>>>Sri Gunturi wrote:
>>>>Hi Tom,
>>>>in the .log file?
>>>>Regards,
>>>>Sri.
>>>>Tom Schindl wrote:
>>>>>Hi,
>>>>>some
>>>>>Tom
Re: Custom SWT-Widget added but not drawn [message #647658 is a reply to message #611688] |
Fri, 07 January 2011 11:14  |
Hi Tom!
Did you manage to get your custom TableColumn (as you stated "TextColumn extends TableColumn") to be displayed on VE?
I'm trying to add a very simple "CustomTableColumn" to a Table on VE, but every time I select my bean, VE actually adds a standard "TableColumn" instead...
I'm sorry ask, but I can't get my "CustomTableColumn" to be shown on VE, and I keep wondering why, or if it is possible at all...
Thanks in advance!
Douglas
Current Time: Sun Jul 27 04:14:20 EDT 2025
Powered by FUDForum. Page generated in 0.07536 seconds
