Get IProject and IFile from a ICompilationUnit [message #112837] |
Sun, 02 November 2003 20:12  |
Originally posted by: esalbuquerque.superig.com.br
how can I get IProject and IFile from a ICompilationUnit or
IWorkingCopyManager ?
For example, from snippet code:
IWorkbenchPage wbp = window.getActivePage();
IEditorPart edt = wbp.getActiveEditor();
IEditorInput ei = edt.getEditorInput();
IWorkingCopyManager mgr = JavaUI.getWorkingCopyManager();
try {
mgr.connect(ei);
ICompilationUnit unit = mgr.getWorkingCopy(ei);
source = unit.getSource();
if (unit == null) {
System.out.print("Nao eh um arq. Java");
return;
} else {
CompilationUnit cUnit = AST.parseCompilationUnit(unit, true);
cUnit.accept(sav);
} catch (Throwable e) {
e.printStackTrace();
} finally {
mgr.disconnect(ei);
Eduardo Soares Albuquerque
Re: Get IProject and IFile from a ICompilationUnit [message #113326 is a reply to message #112837] |
Mon, 03 November 2003 17:56   |
Originally posted by: dave_s42.hotmail.com
Sorry, this isn't an answer, but another question building on yours. I
need to do the same thing (get an IFile) and I see what the posted code
snippet is getting at. What I don't get is the window.getActivePage()
call. It would seem as if window is an IWorkbenchWindow, correct? If
that's true, then where is it created/referenced? (ie, how does the
variable name 'window' get bound to something meaningful?)
Eduardo Soares Albuquerque wrote:
> Hello,
> try {
> mgr.connect(ei);
> if (unit == null) {
> return;
> } else {
> cUnit.accept(sav);
> } finally {
> mgr.disconnect(ei);
Re: Get IProject and IFile from a ICompilationUnit [message #113417 is a reply to message #113326] |
Tue, 04 November 2003 03:40  |
>public class XXXX implements IWorkbenchWindowActionDelegate {
> private IWorkbenchWindow window;
> > Hello,
> > try {
> > mgr.connect(ei);
> > if (unit == null) {
> > return;
> > } else {
> > cUnit.accept(sav);
> > } finally {
> > mgr.disconnect(ei);
> > Thanks,
FUDForum. Page generated in 0.28824 seconds
