Home » Eclipse Projects » Remote Application Platform (RAP) » RAP deployment
RAP deployment [message #112527] Mon, 17 November 2008 05:00 Go to next message
I have been worked for three days on the RAP deployment of the demo.
Without success.
I'm referring to
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.rap.help/help/html/intro.html
I tried it step by step and several times, but it doesn't work. I also
tried to search here without success.
When I deploy my rap.war ( zip auf WEB-INF) in tomcat and start it under
http://localhost:8080/rap/rap. The following error occurs:
The requested resource (BridgeServlet: /rap/rap) is not available.
The deployment auf the rapdemo.war works fine.
The tomcat log-file says quit a lot, but I don't find the reason for my
problem:
!SESSION 2008-11-17 10:52:27.503
eclipse.buildId=unknown
java.version=1.6.0_07
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -console
!ENTRY org.eclipse.equinox.http.servletbridge 4 0 2008-11-17 10:52:27.503
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Import-Package:
org.eclipse.equinox.servletbridge; version="1.0.0"
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:616)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:299)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:489)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:321)
!ENTRY org.eclipse.rap.demo 4 0 2008-11-17 10:52:27.534
!MESSAGE
!STACK 0
Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui;
bundle-version="0.0.0"
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.rap.ui.workbench 4 0 2008-11-17 10:52:27.550
!MESSAGE
!STACK 0
org.eclipse.rap.jface.databinding; bundle-version="[1.1.0,2.0.0)"
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.rap.ui 4 0 2008-11-17 10:52:27.550
!MESSAGE
!STACK 0
Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui.workbench;
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.equinox.http.servletbridge 4 0 2008-11-17 10:52:28.081
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.equinox.http.servletbridge.internal.Activator for bundle
org.eclipse.equinox.http.servletbridge is invalid
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:980)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
at
at
org.eclipse.osgi.framework.internal.core.PackageAdminImpl.re sumeBundles(PackageAdminImpl.java:272)
at
org.eclipse.osgi.framework.internal.core.PackageAdminImpl.pr ocessDelta(PackageAdminImpl.java:506)
at
org.eclipse.osgi.framework.internal.core.PackageAdminImpl.do ResolveBundles(PackageAdminImpl.java:224)
at
org.eclipse.osgi.framework.internal.core.PackageAdminImpl$1. run(PackageAdminImpl.java:162)
Caused by: java.lang.VerifyError: (class:
org/eclipse/equinox/http/servletbridge/internal/Activator, method: stop
signature: (Lorg/osgi/framework/BundleContext;)V) Incompatible argument to
function
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
... 9 more
Root exception:
function
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 4 0 2008-11-17 10:52:28.112
!MESSAGE Bundle
initial@reference :file:plugins/org.eclipse.equinox.http.servletbridge_1.0.0.2 00811171047.jar/
[10] is not active.
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.rap.demo_1.1.1.20080917-1625.jar/
was not resolved.
!MESSAGE Bundle
initial@reference :file:plugins/org.eclipse.rap.ui.workbench_1.1.1.20080917-16 25.jar/
was not resolved.
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.rap.ui_1.1.1.20080917-1625.jar/
was not resolved.
I really would appreciate some help
May
Re: RAP deployment [message #112544 is a reply to message #112527] Mon, 17 November 2008 05:53 Go to previous messageGo to next message
there's a VerifyError in one of the Bundle activators. Could it be that
you use different Java versions for compiling and starting your app?
Stefan.
Re: RAP deployment [message #112557 is a reply to message #112544] Mon, 17 November 2008 07:27 Go to previous messageGo to next message
You are right. I have changed to 1.6
But the problem doesn't seem to be resolved
Any ideas?
Thanks in advance,
May
Current serverlog:
!SESSION 2008-11-17 13:22:02.576
!ENTRY org.eclipse.osgi 4 0 2008-11-17 13:22:02.576
!MESSAGE Bundle
org.eclipse.equinox.http.servletbridge_1.0.0.200811171047.ja r @start not
found.
!ENTRY org.eclipse.rap.demo 4 0 2008-11-17 13:22:03.655
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.rap.ui.workbench 4 0 2008-11-17 13:22:03.655
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.rap.ui 4 0 2008-11-17 13:22:03.655
!MESSAGE
!STACK 0
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 4 0 2008-11-17 13:22:04.045
!MESSAGE Bundle
was not resolved.
!MESSAGE Bundle
was not resolved.
!MESSAGE Bundle
was not resolved.
Re: RAP deployment [message #112569 is a reply to message #112557] Mon, 17 November 2008 12:00 Go to previous messageGo to next message
I've run into this problem before. Make sure that all of the bundles in
your Dependencies tab of your plugin.xml file are also checked for your
Run Configuration. What I usually do is click the "add required plugins"
button in my configuration, and that usually does the trick.
Also be sure to add this to your VM arguments box of your Arguments Run
Configuration tab:
-Declipse.ignoreApp=true -Dosgi.noShutdown=true
That way the Eclipse Console will display while running your Rap
application. It would be helpful for you to run the "ss" command and send
us that output if you are still having problems.
Re: RAP deployment [message #112620 is a reply to message #112569] Tue, 18 November 2008 06:01 Go to previous messageGo to next message
Just to make sure you get me right.
I'm trying to deploy the rapdemo with org.eclipse.rap.demo and
org.eclipse.rap.demo.feature. I have no problems with starting the
rapdemo from eclipse. Also typing ss in the consol looks find, too.
I followed the instruction to deploy the war file from the tutorial. I
deploy the war-file with the tomcat-manager
http://localhost:8080/manager/html/. There I have no option to type ss or
to show the consol. I'm just guessing that, anyway.
The function "add required plugins" has also no affect. It seems to be
okay.
Are the any Problems with Eclipse 3.4? When I run the webappBuilder.xml
and then replace all jars except from the org.eclipse.rap.demo.jar with
the content of the calc.war of a different tutorial, I get at least an
error message in the browser and logs (deploy war(rap.war) in tomcat and
start http://localhost:8080/rap/rap).
Do you have an Idea for solving my problem or a better/different way to
deploy the simple project to a war-file?
Thanks in advance and sorry for bugging
May
Re: RAP deployment [message #112702 is a reply to message #112620] Wed, 19 November 2008 05:15 Go to previous messageGo to next message
it's me again
here the output of the ss command:
0 ACTIVE org.eclipse.osgi_3.3.0.v20070530
Fragments=18
1 ACTIVE org.eclipse.equinox.common_3.3.0.v20070426
2 INSTALLED org.eclipse.rap.demo_1.1.1.20080917-1625
3 ACTIVE org.eclipse.update.configurator_3.2.101.R33x_v20070810
4 ACTIVE
org.eclipse.equinox.http.servletbridge_1.0.0.200712051252
5 ACTIVE org.eclipse.equinox.http.registry_1.0.100.200712051252
6 RESOLVED org.eclipse.core.commands_3.3.0.I20070605-0010
7 ACTIVE org.eclipse.core.contenttype_3.2.100.v20070319
8 ACTIVE org.eclipse.core.expressions_3.3.0.v20070606-0010
9 ACTIVE org.eclipse.core.jobs_3.3.0.v20070423
10 ACTIVE org.eclipse.core.runtime_3.3.100.v20070530
11 ACTIVE org.eclipse.equinox.app_1.0.0.v20070606
15 ACTIVE org.eclipse.equinox.http.servlet_1.0.100.200712051252
16 ACTIVE org.eclipse.equinox.preferences_3.2.100.v20070522
17 ACTIVE org.eclipse.equinox.registry_3.3.0.v20070522
18 RESOLVED org.eclipse.equinox.servletbridge.extensionbundle_1.0.0
Master=0
19 RESOLVED org.eclipse.osgi.services_3.1.200.v20070605
22 RESOLVED org.eclipse.rap.jface_1.0.0.20071010-2241
23 RESOLVED org.eclipse.rap.rwt_1.0.0.20071010-2241
24 ACTIVE org.eclipse.rap.ui.workbench_1.0.0.20071010-2241
25 RESOLVED org.eclipse.rap.ui_1.0.0.20071010-2241
I don't get why
is not ACTIVE/RESOLVED
I would really appreciate your help
May
Re: RAP deployment [message #112715 is a reply to message #112702] Wed, 19 November 2008 07:39 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
> Fragments=18
> 4 ACTIVE
> Master=0
At least the org.eclipse.rap.rwt.q07 fragment seems to be missing. If
the application runs fine from inside eclipse, I'd recommend to compare
the list of bundles in your launch config with this one.
> I don't get why INSTALLED org.eclipse.rap.demo_1.1.1.20080917-1625
you can type `diag 2` in the OSGi console to find out.
Best regards, Ralf
Re: RAP deployment [message #112728 is a reply to message #112715] Wed, 19 November 2008 08:33 Go to previous messageGo to next message
That was very helpful Ralf,
There were unresolved bundles…
I also had some jar-version problems. I solved my problem by replacing all
jars with the jars from the rapdemo.war and adjust the config.ini by hand.
I'm excusing for asking (maybe) so simple questions, because I'm very new
to this.
Now, where I'm able to deploy an RAP as war-file, I try to deploy my own
rap-application.
ss shows no "INSTALLED" bundles, but when I start myRapApp the next
problem occurs:
Exception in thread "UIThread [886947ACCFA0FB85FC8620E666D00233]"
java.lang.Ille
galStateException: The context has been disposed.
at
org.eclipse.rwt.internal.service.ServiceContext.checkState(U nknown So
urce)
at
org.eclipse.rwt.internal.service.ServiceContext.getRequest(U nknown So
urce)
at
org.eclipse.rwt.internal.service.ContextProvider.getRequest( Unknown S
ource)
at
org.eclipse.rwt.internal.service.ContextProvider.getSession( Unknown S
ource)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.setShutdownA dapter(Un
known Source)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.access$0(Unk nown Sour
ce)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.ru
n(Unknown Source)
Any hints on what that supposed to be mean?
Thanks for supporting me,
May
Re: RAP deployment [message #112781 is a reply to message #112728] Wed, 19 November 2008 10:22 Go to previous messageGo to next message
Oh sorry guys,
I just solved it, my fault.
Thanks again
Re: RAP deployment [message #1830353 is a reply to message #112527] Thu, 23 July 2020 17:08 Go to previous messageGo to next message
To the person that started this question, could you provide "how" you solved, as I am having the exact same error and I am at wits end.
Re: RAP deployment [message #1830366 is a reply to message #1830353] Fri, 24 July 2020 04:50 Go to previous message
in the RAP repository you can find a maven project [1] that builds all RAP demos.
[1] https://github.com/eclipse/rap/tree/master/releng/org.eclipse.rap.examples.build
HTH,
Ivan Furnadjiev
Previous Topic:UIThreads / EntryPoints
Next Topic:Uploading Files with html spcial charachters fails
Current Time: Sat Jul 19 13:06:28 EDT 2025
Powered by FUDForum. Page generated in 0.05553 seconds
