Home » Eclipse Projects » e(fx)clipse » JavaFx event locking problems with JRE 7u40
JavaFx event locking problems with JRE 7u40 [message #1115857] Tue, 24 September 2013 13:28 Go to next message
For an RCP application under eclipse 3.8.2, efxclipse 0.8.1, jre7u40 I have the following problem:
If a JFace dialog with an FxCanvas was opened through a javafx event, all javafx controls in the application lock and don't process events until the dialog closes.
This problem just appeared under 7u40 but didn't happen on the previous jres.
Here is some example code. A JFace Dialog with a javafx 'Open' button in an FxCanvas. Both the 'Open' and the dialog's 'Ok' button open a new instance of the dialog.
https://dl.dropboxusercontent.com/u/44493241/Clipboard01.png
import javafx.embed.swt.FXCanvas;
import javafx.event.ActionEvent;
import javafx.event.EventHandler;
import javafx.geometry.Insets;
import javafx.scene.Parent;
import javafx.scene.Scene;
import javafx.scene.control.Button;
import javafx.scene.layout.StackPane;
import org.eclipse.jface.dialogs.Dialog;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Shell;
public class TestFx extends Dialog {
	public TestFx(Shell parent) {
		super(parent);
		setShellStyle(SWT.MODELESS | SWT.DIALOG_TRIM);
	public void okPressed() {
		TestFx dialog = new TestFx(Display.getDefault().getActiveShell());
		dialog.open();
	protected Control createDialogArea(Composite parent) {
		Composite container = (Composite) super.createDialogArea(parent);
		container.setLayout(new FillLayout());
		FXCanvas fxCanvas = new FXCanvas(container, SWT.NONE);
		Scene scene = new Scene(createScene());
		fxCanvas.setScene(scene);
		return container;
	public Parent createScene() {
		StackPane pane = new StackPane();
		pane.setPadding(new Insets(10));
		Button button = new Button("Open");
		button.setOnAction(new EventHandler<ActionEvent>() {
			@Override public void handle(ActionEvent e) {
				dialog.open();
		pane.getChildren().add(button);
		return pane;
I open the first dialog through an action in the application's menubar.
projectMenu.add(new Action("TestFx"){
	public void run() {
		dialog.open();
The javafx 'open' button works as long as the dialog was created from the menu action or the 'ok' button but not if it was created by the 'Open' button. In the latter case all javafx controls (also the ones in FxCanvas belonging to other shells) freeze until the dialog closes (the swt ui stays responsive). These events however are put into a queue and are processed once the dialog closes. Note also that the layout of the fxcanvas fails as can be seen in the picture above where the right dialog was opened through the 'open' button of the left dialog.
If I run this not from eclipse but from a simple swt application there is no locking and the layout stays correct
	Display display = new Display();
	Shell shell = new Shell(display);
	TestFx dialog  = new TestFx(shell);
	dialog.open();
Any ideas what the underlying problems could be and how to fix this?
[Updated on: Tue, 24 September 2013 15:26] by Moderator
Re: JavaFx event locking problems with JRE 7u40 [message #1115957 is a reply to message #1115857] Tue, 24 September 2013 16:30 Go to previous messageGo to next message
On what OS? Does it only happen in dialogs? If this fails the
FXML-Preview would fail as well. Your description sounds like FX is not
hooked appropriately into the native event loop.
There was a fix [1] for SWT/Linux maybe this has introduced a regression
Tom
[1]https://javafx-jira.kenai.com/browse/RT-23411
On 24.09.13 19:28, Timm Baumeister wrote:
> Under eclipse 3.8.2, efxclipse 0.8.1, jre7u40 I have the following problem:
> all javafx controls in the application lock and don't accept events
> jres.
> super(parent);
> @Override
> TestFx d = new TestFx(getShell());
> d.open();
> @Override
> return container;
> TestFx d = new
> d.open();
> return pane;
> I open the first dialog through a menubar action:
> @Override
> public void run() {
> logger.info(Thread.currentThread().getName());
> dialog.open();
> swt ui stays responsive). Note also that the layout of the fxcanvas
> If I open the dialog not from eclipse but from a simple swt application
> there is no locking:
> public static void main(String[] args) {
> while (true) {
> MyDialog d = new MyDialog(shell);
> d.open();
Re: JavaFx event locking problems with JRE 7u40 [message #1116160 is a reply to message #1115957] Tue, 24 September 2013 23:36 Go to previous messageGo to next message
Thomas Schindl wrote on Tue, 24 September 2013 16:30
I am running it on win32.
After more tests with ViewParts/Dialogs/Shells the pattern seems to be:
The lockup of the javafx event processing under 7u40 happens whenever a Jface Dialog is opened through a javafx event. It does not matter if the Dialog contains an FxCanvas itself, also modality of the dialog doesn't matter. If the JFace Dialog is replaced by a shell, no lockup appears.
[Updated on: Tue, 24 September 2013 23:37] by Moderator
Re: JavaFx event locking problems with JRE 7u40 [message #1116266 is a reply to message #1116160] Wed, 25 September 2013 03:08 Go to previous messageGo to next message
Can you please file a JIRA against FX? Please cc me on the ticket, I
hope Steve can find out what happens. So the workaround would be to open
only JavaFX-Dialogs from within JavaFX :-)
If you have a snippet to reproduce this in plain SWT I could give it a
spin in OS-X or don't want to create the account i could file a the JIRA
on behalf of you
We have a JFace like dialog classes in e(fx)clipse if you are interested
in. I would BTW suggest you update to the nightly builds - which are
stable - because I've improved the dialog support lately.
Tom
> After some more tests with ViewParts/Dialogs/Shells the pattern seems to
> be:
Re: JavaFx event locking problems with JRE 7u40 [message #1116678 is a reply to message #1116266] Wed, 25 September 2013 14:38 Go to previous messageGo to next message
Thomas Schindl wrote on Wed, 25 September 2013 03:08
only JavaFX-Dialogs from within JavaFX Smile
on behalf of you
Are you sure that this is an issue which belongs into the fx jira? To me it looks so far as if it is related to how fx is bound into eclipse (as it is not happening when using plain swt). I can't give you a plain SWT test case, but I can provide a simple eclipse plugin test case. If you tell me that this should be considered as an fx issue I will file it in their jira.
I have a much simpler test case now without the jface dialog. What happens is that an swt event loop doesn't process fx events if created from within fx. Here the test case:
import org.eclipse.swt.events.MouseAdapter;
import org.eclipse.swt.events.MouseEvent;
public class TestFx  {
	static public void test() {
		Display display = Display.getDefault();
		Shell shell = new Shell(display.getActiveShell(),SWT.MODELESS | SWT.BORDER | SWT.CLOSE);
		shell.setLayout(new FillLayout());
		// fx open shell button
		FXCanvas fxCanvas = new FXCanvas(shell, SWT.NONE);
		Button button = new Button("FX Open Shell");
				test();
		Scene scene = new Scene(pane);
		// swt open shell button
		org.eclipse.swt.widgets.Button b = new org.eclipse.swt.widgets.Button(shell, SWT.NONE);
		b.setText("SWT Open Shell");
		b.addMouseListener(new MouseAdapter() {
			public void mouseDown(MouseEvent e) {
				test();
		shell.pack();
		shell.open ();
		/* event loop
		 	- processes swt/fx events if test() was called from swt
			- processes only swt but no fx events if test() was called from fx
			  all fx events during this time will be processed only after the event loop terminates */
		while (!shell.isDisposed()) {
			try {
				if (!display.readAndDispatch()) {
					display.sleep();
			} catch (Throwable e) {
				e.printStackTrace();
	// lockup does not occur if this is run as a standalone swt app
		test();
I looked at the the call stacks when calling this in plain swt and in eclipse, which are identical except for:
Plain SWT
PlatformImpl$4.run() line: 176
OS.DispatchMessageW(MSG) line: not available [native method]
OS.DispatchMessage(MSG) line: 2546
Display.readAndDispatch() line: 3756
Eclipse
InvokeLaterDispatcher$Future.run() line: 76
Re: JavaFx event locking problems with JRE 7u40 [message #1116706 is a reply to message #1116678] Wed, 25 September 2013 15:09 Go to previous messageGo to next message
FXCanvas is the problem and this is part of JavaFX. So yes I'm sure this
is a problem of FXs FXCanvas implementation.
I'll try to come up with a standalone SWT-App and file a JIRA.
Tom
>> only JavaFX-Dialogs from within JavaFX :)
>> on behalf of you
> their jira.
> import org.eclipse.swt.widgets.Display;
> test();
> @Override
> test();
> shell.pack();
> shell.open ();
> /* event loop - processes swt/fx events if test()
> was called from swt
> from fx
> try {
> display.sleep();
> test();
> Plain SWT
> Eclipse
Re: JavaFx event locking problems with JRE 7u40 [message #1121617 is a reply to message #1116706] Mon, 30 September 2013 16:23 Go to previous message
So the bug is accepted by Steve ;-)
https://javafx-jira.kenai.com/browse/RT-33258
Tom
> Tom
>>> on behalf of you
>> their jira.
>> test();
>> @Override
>> test();
>> shell.pack();
>> shell.open ();
>> was called from swt
>> from fx
>> try {
>> display.sleep();
>> test();
>> Plain SWT
>> Eclipse
Previous Topic:Deployment to exe
Next Topic:Maven build fails
Current Time: Sat Jul 19 10:00:12 EDT 2025
Powered by FUDForum. Page generated in 0.25022 seconds
