Home » Eclipse Projects » Remote Application Platform (RAP) » SWTException in CoolBarManager on disposed CoolItem
SWTException in CoolBarManager on disposed CoolItem [message #1115475] Tue, 24 September 2013 02:46 Go to next message
We've got SWTException in our application based on RAP 2.1.
There are several coolItems iterated in CoolBarManager2
(CoolBarManager).update(boolean) line: 952
and updated.
During update the one of the iterated CoolItems is disposed and when the iterator will be on it - the SWTException thrown on getData method:
// Retrieve the corresponding contribution item from SWT's
                // data.
                if (sourceIndex < coolItems.length) {
                    destinationItem = (IContributionItem) coolItems[sourceIndex]
                            .getData();
                } else {
                    destinationItem = null;
Here is the stack of the CoolItem disposing.
	CoolItem.dispose() line: 281
	ToolBarContributionItem2(ToolBarContributionItem).updateSize(boolean) line: 639
	ToolBarContributionItem2(ToolBarContributionItem).update(String) line: 595
	CoolBarManager$1.controlResized(ControlEvent) line: 267
	TypedListener.handleEvent(Event) line: 256
	EventTable.sendEvent(Event) line: 85
	CoolBar(Widget).sendEvent(Event) line: 700
	CoolBar(Widget).notifyListeners(int, Event) line: 602
	CoolBar(Control).notifyResize(Point) line: 2416
	CoolBar(Composite).notifyResize(Point) line: 882
	CoolBar(Control).setBounds(Rectangle, boolean) line: 2401
	CoolBar(Control).setBounds(Rectangle) line: 855
	CoolBar(Control).setSize(Point) line: 969
	CoolBar(Control).setSize(int, int) line: 989
	CoolBar.relayout() line: 1025
	CoolBar.destroyItem(CoolItem) line: 537
	CoolItem.dispose() line: 288
	CoolItem.setSize(int, int) line: 724
	CoolItem.setSize(Point) line: 753
	ToolBarContributionItem2(ToolBarContributionItem).updateSize(boolean) line: 662
	ToolBarContributionItem2(ToolBarContributionItem).fill(CoolBar, int) line: 251
	CoolBarManager2(CoolBarManager).update(boolean) line: 952
	SubCoolBarManager.update(boolean) line: 99
	VisualReportViewerContributor(AbstractPageEditorContributor).updateBars() line: 481
	VisualReportViewerContributor(AbstractPageEditorContributor).updateActiveContributor() line: 445
	VisualReportViewerContributor(AbstractPageEditorContributor).setActivePage(IEditorPart) line: 179
	VisualReportViewerContributor(MultiPageEditorActionBarContributor).setActiveEditor(IEditorPart) line: 51
	VisualReportViewerContributor(AbstractPageEditorContributor).setActiveEditor(IEditorPart) line: 102
	EditorActionBars.partChanged(IWorkbenchPart) line: 343
	WorkbenchPage$3.run() line: 638
	SafeRunner.run(ISafeRunnable) line: 42
	Platform.run(ISafeRunnable) line: 854
	WorkbenchPage.activatePart(IWorkbenchPart) line: 627
	WorkbenchPage.setActivePart(IWorkbenchPart, boolean) line: 3527
	WorkbenchPage.internalActivate(IWorkbenchPart, boolean) line: 620
	WorkbenchPage.activate(IWorkbenchPart) line: 592
	WorkbenchPage.busyOpenEditorBatched(IEditorInput, String, boolean, int, IMemento) line: 2870
	WorkbenchPage.busyOpenEditor(IEditorInput, String, boolean, int, IMemento) line: 2763
	WorkbenchPage.access$11(WorkbenchPage, IEditorInput, String, boolean, int, IMemento) line: 2755
	WorkbenchPage$10.run() line: 2706
	BusyIndicator.showWhile(Display, Runnable) line: 66
	WorkbenchPage.openEditor(IEditorInput, String, boolean, int, IMemento) line: 2702
	WorkbenchPage.openEditor(IEditorInput, String, boolean, int) line: 2686
	IDE.openEditor(IWorkbenchPage, IEditorInput, String, boolean, int) line: 209
	IDE.openEditor(IWorkbenchPage, IEditorInput, String, int) line: 126
	IDE.openEditor(IWorkbenchPage, IEditorInput, String) line: 95
	RAPDocumentService(DocumentService).internalOpenEditor(IDocument, Map, boolean) line: 711
	DocumentService.access$8(DocumentService, IDocument, Map, boolean) line: 665
	DocumentService$1.run() line: 550
	RunnableLock.run() line: 38
	UISynchronizer(Synchronizer).runAsyncMessages(boolean) line: 180
	Display.runPendingMessages() line: 1189
	Display.safeReadAndDispatch() line: 1169
	Display.readAndDispatch() line: 1161
	Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2733
	Workbench.runUI() line: 2694
	Workbench.access$5(Workbench) line: 2530
	Workbench$5.run() line: 701
	Realm.runWithDefault(Realm, Runnable) line: 332
	Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 684
	PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 157
	BiAdminEntryPoint.createUI(Display) line: 56
	BiAdminEntryPoint(BaseEntryPoint).createUI() line: 160
	RWTLifeCycle.createUI() line: 186
	RWTLifeCycle$UIThreadController.run() line: 298
	UIThread(Thread).run() line: 619
	UIThread.run() line: 104
Removing the org.eclipse.jface.action.CoolBarManager.addCoolBarResizeListener() method solves the p[roblem, but it seems to me not a cause and solution.
Can you provide some thoughts about this and, probably, confirm a bug?
Yury.
Re: SWTException in CoolBarManager on disposed CoolItem [message #1115499 is a reply to message #1115475] Tue, 24 September 2013 03:22 Go to previous messageGo to next message
Hi Yury,
the coolbar resize listener is RAP specific code (workaround for text
size determination issues) and it's probably a bug in RAP.
If item is disposed the call
coolItems = coolBar.getItems(); (line 907)
should not return it. For me it sounds like a bug in CoolItem disposal code.
Could you investigate why CoolBar#getItems() returns disposed items?
Also please open a bugzilla with a snippet to reproduce the issue.
Ivan
> and updated.
> // data.
> .getData();
> } else {
> line: 639
> line: 595
> line: 639
> line: 595
> line: 662
> int) line: 251
> line: 481
> line: 445
> line: 179
> line: 51
> line: 102
> 2686
> line: 209
> line: 665
> Removing the
> Best regards,
> Yury.
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: SWTException in CoolBarManager on disposed CoolItem [message #1115539 is a reply to message #1115499] Tue, 24 September 2013 04:27 Go to previous messageGo to next message
Hello, Ivan!
First of all, Thank you for quick response!
Does not return disposed item - it will be disposed later in
sourceItem.fill(coolBar, destinationIndex);
by calling relayout, size changing and listeners calling - where the CoolItem from coolBar.getItems() collection will be disposed (note that it will be disposed twice, see org.eclipse.swt.widgets.CoolItem.dispose()
 public void dispose() {
    if ( isDisposed() )
      return;
     * Must call parent.destroyItem() before super.dispose(), since it needs to
     * query the bounds to properly remove the item.
    parent.destroyItem( this ); <-- calling this before super.dispose() leads to calling CoolItem.dispose again
    super.dispose();
    parent = null;
    control = null;
     * Although the parent for the chevron is the CoolBar (CoolItem can not be
     * the parent) it has to be disposed with the item
    if ( chevron != null && !chevron.isDisposed() )
      chevron.dispose();
    chevron = null;
    if (arrowImage != null && !arrowImage.isDisposed()) arrowImage.dispose();
    arrowImage = null;
It is not pretty simple to create a snippet, that is why I'm asking here for help Smile
Yury.
Re: SWTException in CoolBarManager on disposed CoolItem [message #1115629 is a reply to message #1115539] Tue, 24 September 2013 07:02 Go to previous messageGo to next message
Hi Yury,
do you have a proposal for a fix without removing the coolbar resize
listener?
Best,
Ivan
On 9/24/2013 11:27 AM, Yury Mising name wrote:
> Hello, Ivan!
> if ( isDisposed() )
> return;
> needs to
> super.dispose();
> parent = null;
> control = null;
> not be
> chevron.dispose();
> chevron = null;
> arrowImage = null;
> here for help :)
> Best regards,
> Yury.
Ivan Furnadjiev
Re: SWTException in CoolBarManager on disposed CoolItem [message #1116269 is a reply to message #1115629] Wed, 25 September 2013 03:11 Go to previous messageGo to next message
Hello, Ivan.
The rough patch which fix the problem without removing listeners - additional checking iterated CoolItem on disposed state:
diff --git a/bundles/org.eclipse.rap.jface/src/org/eclipse/jface/action/CoolBarManager.java b/bundles/org.eclipse.rap.jface/src/org/eclipse/jface/action/CoolBarManager.java
old mode 100755
new mode 100644
index 1f8e297..a2537c3
--- a/bundles/org.eclipse.rap.jface/src/org/eclipse/jface/action/CoolBarManager.java
+++ b/bundles/org.eclipse.rap.jface/src/org/eclipse/jface/action/CoolBarManager.java
@@ -915,7 +915,7 @@
                 // data.
-                if (sourceIndex < coolItems.length) {
+                if (sourceIndex < coolItems.length && !coolItems[sourceIndex].isDisposed()) {
                             .getData();
                 } else {
In this case the SWTExcpetion will not thrown on getData().
Yury.
Re: SWTException in CoolBarManager on disposed CoolItem [message #1116280 is a reply to message #1116269] Wed, 25 September 2013 03:26 Go to previous messageGo to next message
Hi Yury,
please open a bugzilla and attach the patch there.
Ivan
On 9/25/2013 10:11 AM, Yury Mising name wrote:
> Hello, Ivan.
> diff --git
> old mode 100755
> new mode 100644
> @@ -915,7 +915,7 @@
> SWT's
> // data.
> .getData();
> } else {
> Best regards,
> Yury.
Ivan Furnadjiev
Re: SWTException in CoolBarManager on disposed CoolItem [message #1116327 is a reply to message #1116280] Wed, 25 September 2013 04:54 Go to previous message
Done - https://bugs.eclipse.org/bugs/show_bug.cgi?id=417989
Previous Topic:How to do a Synchronous call to custom widgets java backend
Next Topic:add bookmark/favorit using javascript
Current Time: Wed Jul 23 11:58:11 EDT 2025
Powered by FUDForum. Page generated in 0.05321 seconds
