Home » Archived » Buckminster » build command that proceeds on error
build command that proceeds on error [message #1114137] Sun, 22 September 2013 04:12 Go to next message
is there a way to tell buckminster, when executing the build command, to
proceed in case of errors? For instance, the import command has the
command line argument --continueonerror.
The reason why I would need that is that I managed to compile xtend
files with the xtend command line compiler in a buckminster build, but
in order to achieve that I first need to perform a first build so that
some Java files, which the xtend files depend on, are compiled. Only a
few Java files will be compiled and the build will fail, but this is
enough to compile xtend files to Java files. Then I'll perform a second
build and it will succeed.
For the moment, I managed to achieve that by performing the first build
in a separate buckminster run, ignoring the failure. But it would be
nice to have a "build --continueonerror" so that I can do everything in
one shot (i.e., with a single commands file).
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: build command that proceeds on error [message #1114168 is a reply to message #1114137] Sun, 22 September 2013 05:26 Go to previous messageGo to next message
Hi Lorenzo,
We don't have a --continueonerror flag. Seems like a reasonable addition though. Please enter an enhancement request for it.
- thomas
On 2013-09-22 10:12, Lorenzo Bettini wrote:
> Hi
> cheers
> Lorenzo
Re: build command that proceeds on error [message #1116413 is a reply to message #1114168] Wed, 25 September 2013 07:56 Go to previous message
Done https://bugs.eclipse.org/bugs/show_bug.cgi?id=418009
and there's also a patch that works for me :)
cheers
Lorenzo
On 22/09/2013 11:26, Thomas Hallgren wrote:
> Hi Lorenzo,
> - thomas
>> Hi
>> cheers
>> Lorenzo
Xtext Book:
Previous Topic:platform-independent target platform
Next Topic:Trigger Xtend 2 builder in a headless CI job using ant / classpath problem
Current Time: Sat Jul 26 11:39:02 EDT 2025
Powered by FUDForum. Page generated in 0.07308 seconds
