| Why does activating a task not open it? [message #11076] | Fri, 13 July 2007 11:06  |  |
| Eclipse User  |  |  |  |  | Much is made of the "one click" activation, but if I right click on an inactive task and Activate it the task is not opened into the
 editor.  Is there a reason why it does not?
 Also does Activating a task Deactivate the task that was previously open?
 i.e. can only one task be active at a time.  If not, how do I find a list
 of the currently active tasks?
 David
| Re: Why does activating a task not open it? [message #14027 is a reply to message #12523] | Mon, 16 July 2007 14:55  |  |
| Eclipse User  |  |  |  |  | Originally posted by: xiaoyang.guan.gmail.com
 Mik Kersten wrote:
 > Xiaoyang Guan wrote:
 >> How about a simple click to activate a task will restore editors
 >> exactly as when they were last deactivated; and Ctrl+click (or some
 >> other combination if this is already used for another purpose) to
 >> activate will open the task editor on top of the others?
 > Sounds good go me.  It may be an advanced and hard to discover UI and we
 > might have some challenges picking the right modifier key without losing
 > existing tree functionality, but the bottom line is that some version of
 > this will provide users with an an open/activate mode that brings the
 > task to the top.  Please file a bug.
 > Mik
 Done -- bug 196711: https://bugs.eclipse.org/bugs/show_bug.cgi?id=196711
| Re: Why does activating a task not open it? [message #571541 is a reply to message #11076] | Fri, 13 July 2007 12:33  |  |
| Eclipse User  |  |  |  |  | David Goodenough wrote: > Much is made of the "one click" activation, but if I right click
 Good question.  We keep trying to figure out a way to make this work,
 but there are two competing use cases for what happens when getting back
 to a task:
 1) Want to see the last thing I worked on (e.g. the exact Java method
 being edited) and want my workbench look just like it did when I
 deactivated.
 2) Need to be reminded of what the task is a bout (i.e. by looking at
 the task itself).
 So the current policy is to restore your editors to exactly what they
 were when you deactivated.  But this means that I find myself clicking
 the task hyperlink in the Task List view quite frequently when , and am
 thankful that it tends to be wide ;)
 Anyone have any ideas for how to improve this policy?  We go as far as
 doing something fancy like restoring editors but forcing the task editor
 to be the 2nd editor.
 Yes, only one task can be active.  Mylyn 0.2 allowed multiple active
 task but the UI ended up way too complex as a result so we axes this.
 For switching between recently activated tasks use the switcher visible
 in the upper-right of the third screenshot at:
 http://www.eclipse.org/mylyn/new/
 Mik
| Re: Why does activating a task not open it? [message #571609 is a reply to message #11084] | Fri, 13 July 2007 14:12  |  |
 > to a task:
 > deactivated.
 > the task itself).
 When re-opening a Task the behaviour is fine, the problem is when you first
 open a Task.
 David
 > Mik
| Re: Why does activating a task not open it? [message #571702 is a reply to message #11084] | Fri, 13 July 2007 14:42  |  |
| Eclipse User  |  |  |  |  | Mik Kersten wrote: > So the current policy is to restore your editors to exactly what they
 How about a simple click to activate a task will restore editors exactly
 as when they were last deactivated; and Ctrl+click (or some other
 combination if this is already used for another purpose) to activate
 Xiaoyang
| Re: Why does activating a task not open it? [message #571735 is a reply to message #12502] | Fri, 13 July 2007 15:02  |  |
| Eclipse User  |  |  |  |  | Xiaoyang Guan wrote: > How about a simple click to activate a task will restore editors exactly
 Mik
| Re: Why does activating a task not open it? [message #571773 is a reply to message #12461] | Fri, 13 July 2007 15:04  |  |
| Eclipse User  |  |  |  |  | David Goodenough wrote: > When re-opening a Task the behaviour is fine, the problem is when you first
 > open a Task.
 What would be very straightforward to do, and should meet both your need
 and existing expectations, is to automatically open the editor on
 activation when there are no other relevant editors available to open
 (i.e. you were not working on anything previously).  If you like this
 suggestions please file a bug.
 Mik
| Re: Why does activating a task not open it? [message #572252 is a reply to message #12523] | Mon, 16 July 2007 14:55  |  |
 > Mik
FUDForum. Page generated in 0.05839 seconds
