Home » Eclipse Projects » Equinox » will the new provisioning support restart with different locale?
will the new provisioning support restart with different locale? [message #110065] Wed, 14 May 2008 10:15 Go to next message
Right now there is (still) no decent support for restarting an eclipse
rcp application with different parameters, in particular starting a
client with another locale and keeping that locale in future startup,
one has to programmatically edit config.ini for that or some other trick.
Now it has been suggested in this bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=75320
that the new provision might give some help in this issue.
" ------- Comment #11 From Jeff McAffer 2007-07-09 09:02:55 -0400 -------
there is no such option currently. We may well end up with something that
allows you to programatically edit the config.ini and eclipse.ini files
as part
of the new provisioning work. If that were to happen then you would be
able to
change the configuration to use a particular locale but not just for the
next
run, rather for all subsequent runs.
Has this feature been considered for implementation?
Wouter de Vaal
Re: will the new provisioning support restart with different locale? [message #110446 is a reply to message #110065] Wed, 21 May 2008 23:04 Go to previous messageGo to next message
We now have programmatic API to modify config.ini and eclipse.ini which
therefore could give you the ability to write a preference page for your
user to change the locale.
See the org.eclipse.equinox.frameworkadmin bundle.
"Wouter de Vaal" <wouter_de_vaal@hotmail.com> wrote in message
news:g0es55$ud4$1@build.eclipse.org...
> Right now there is (still) no decent support for restarting an eclipse rcp
> application with different parameters, in particular starting a client
> with another locale and keeping that locale in future startup, one has to
> allows you to programatically edit the config.ini and eclipse.ini files as
> part
> able to
> next
> Regards,
> Wouter de Vaal
Re: will the new provisioning support restart with different locale? [message #110557 is a reply to message #110446] Fri, 23 May 2008 06:57 Go to previous message
Cool. I will give it a spin.
Thanks!
Wouter
>> Hi,
>> part
>> able to
>> next
>> Regards,
>> Wouter de Vaal
Previous Topic:Trouble starting dependent bundle
Next Topic:Help with "Package uses conflict"
Current Time: Mon Jun 16 08:30:41 EDT 2025
Powered by FUDForum. Page generated in 0.07598 seconds
