containments an references [message #108595] |
Fri, 02 March 2007 10:51  |
Originally posted by: pramsohl.in.tum.de
I've got a metamodel to visualize in GMF with two DiagramEditors.
In the first editor i can model "functions" on my canvas together with
other elements. This works fine. Every function is owned by the
metamodel element "car".
In the second editor the user can draw "components" (also children of
car). These components have to contain functions generated by the first
editor (only visually).
- When i specify the component-function relation as containment feature
all the component-functions disappear on the first editor because they
are no longer contained by the object car.
- When i specify the component-function relation as reference i can
generate a mapping with child reference=reference and containment
feature=car. Only with the deprecated "Create generator model" function
i can generate the diagram editor and bypass the warning of gmfmap.
The editor shows up the elements the first time. But deleting deletes
the whole functions and not only the references, and adding doesn't work
properly.
i think the two solutions are:
1) if i use a containment: i have to display not only the car-functions
but also the component-functions on editor1 (maybe with
getModelChildren()????)
2) with reference relation: I have to modify code ind editor2 to support
my behaviour and to refresh the components. I am also happy if i have to
modify the referenced Functions in the properties-view and the diagram
refreshes, but now it refreshes only by adding elements - not by
removing. But maybe this deprecated generation of gmfgen is no longer
avaylabe in the next releases.
How would you solve this Problem. And which of my two proposals is
easier to implement?
Sorry for the long explication.
thank you
Thomas
Re: containments an references [message #109215 is a reply to message #108830] |
Tue, 06 March 2007 07:14   |
Originally posted by: jan.herriger.gmx.de
Hello Thomas,
the link mapping is for drawing connections between components and
functions. By adding a Function into the first editor, it will become a
child of "Car". Afterwards, you can draw a connection from a Component
to a Function. So it will become a child of that Component. EMF handles
this for you.
The editing of the canoncial policy ensures that views for these
connections and nodes are added, if the model was modified externaly.
For example by the second editor.
Thomas schrieb:
> Hello Jan,
> Thank you for your answer - i will try your approach.
> Let me see if i understnd it...
> I've got two containment references in my ecore model.
> The Functions are either contained by Car or by Components.
> In the Function-Editor i modify getSemanticChildrenList() to retrieve
> Component-Functions as well.
> But why do i need this link mapping in my FunctionEditor with only a
> target feature?
> thanks,
> Thomas
> Jan Herriger wrote:
>> Hi Thomas,
>> it is possible to define your component-function relation as
>> containment. For the first editor you can define this containment
>> reference as the target feature in the link mapping.
>> Unfortunately, generated code doesn't support this scenario out of the
>> box. There are serveral modifications to do.
>> xxxCanonicalEditPolicy is one class to edit.
>> It's method "getSemanticChildrenList()" iterates through all model
>> children. Which are your "components". You have to take care, that it
>> iterates through the component's functions as well.
>> In addition, "storeFeatureModelFacetLinks()" has to be modified in
>> order to consider the containment references to the nested function
>> elements.
>> There are some other things to do. But I don't know exactly right now.
>> Best regards
>> Jan
Re: containments an references [message #112619 is a reply to message #109215] |
Sat, 17 March 2007 09:28  |
Hi Jan,
Now i got it.
I modified the canonical policy and it works, thanks.
I don't have to model Compnents on this Diagram - only to display all
the functions of the model.
Is there some GMF or EMF Method to obtain all Elements of a specific
model class? Do i have to iterate through resourceset.allcontents or is
there a simpler way?
Thank you.
Thomas
Jan Herriger wrote:
> Hello Thomas,
> this for you.
> Thomas schrieb:
>> Hello Jan,
>> target feature?
>> thanks,
>> Thomas
>> Jan Herriger wrote:
>>> Hi Thomas,
>>> the box. There are serveral modifications to do.
>>> elements.
>>> Best regards
>>> Jan
FUDForum. Page generated in 0.06925 seconds
