| Managed build schema [message #107990] | Tue, 29 June 2004 02:34  |  |
| Eclipse User  |  |  |  |  | Hello,
 I just started with the new Workbench 3.0/CDT 2.0M9 combination.
 I'm looking for the schema that supports adding a plug-in to the managed
 build extension point. It seems to be missing in CDT 2.0 M9.
 Does anyone know what I should do to create a managed build plug-in for
 this new configuration?
 Marco
| Re: Managed build schema [message #108193 is a reply to message #108152] | Tue, 29 June 2004 14:18   |  |
| Eclipse User  |  |  |  |  | Marco, I used the zip file and the update site. I don't get the schema in
 either case, although I can create a new ManagedBuildInfo extension when
 I properly add the dependency on the managedbuilder.core plugin using
 the zip distribution.
 I'm still looking into why this doesn't seem to work when using the
 update site, but this could well be an error between my ears :-)
 Do you absolutely need the schema? If so, you can always get it
 anonymously from the CVS repository.
 Sean
 Marco Langejans wrote:
 > Sean,
 > I've downloaded CDT from:
 > http://update.eclipse.org/tools/cdt/updates/builds/2.0RC1
 > The product configuration window shows:
 > Eclipse C/C++ Development Tooling SDK 2.0.0
 > Marco
 > Sean Evoy wrote:
 >>Sorry Marco,
 >>I should have asked this question originally. Is this the SDK build or
 >>the "normal" binary build that you are using. I believe that we are only
 >>shipping the schema in the SDK, but if you are using that and seeing
 >>this problem I will look into it.
 >>>Hello,
 >>>Thanks,
 >>>Marco
| Re: Managed build schema [message #108229 is a reply to message #108207] | Wed, 30 June 2004 02:41   |  |
| Eclipse User  |  |  |  |  | Sean, Found it,.. thanks!
 Greetings,
 Marco
 Sean Evoy wrote:
 > Marco,
 > You have to import the org.eclipse.cdt.source plugin and browse to the
 > Managed Build Core plugin; the schema is there.
 > Thanks to Doug Schaefer for pointing me to this,
 > Sean
 > > Sean,
 > > Marco
 > > Sean Evoy wrote:
 > >>Sorry Marco,
 > >>>Hello,
 > >>>Thanks,
 > >>>Marco
| Re: Managed build schema [message #108283 is a reply to message #108123] | Wed, 30 June 2004 07:30  |  |
| Eclipse User  |  |  |  |  | The CDT version that gave the problem described below is CDT2.0R1, stepping back to CDT2.0M9 solved the problem.
 Marco
 > Sean,
 > Nice to be helpful. There's one more thing worrying me:
 > CDT 2.0 M9 plug-ins do not appear in my
 > Preferences|Plug-in Development|TargetPlatform:Plug-ins and Fragments
 > found list. But the plug-ins are in the plug-ins folder with the plug-ins
 > that are listed. Could this also be because of the build settings?
 > Marco Langejans
 > Sean Evoy wrote:
 > > Thanks Marco,
 > > It looks like we missed that in the build settings. I will make sure
 > > that it gets added as part of the binary disctribution for the final build.
 > > > Hello,
 > > > Thanks,
 > > > Marco
FUDForum. Page generated in 0.06965 seconds
