Home » Archived » Test and Performance Tools Platform (TPTP) » Deployement of the material
Deployement of the material [message #107938] Wed, 08 August 2007 12:27 Go to next message
Originally posted by: cguibert.axway.com
Hello
I have a problem when using TPTP: I checked out a working eclipse project
from our internal cvs repository and when I tried to run it from my
machine (on a Unix remote server), all my test was failed.
When I analysed the problem, it seems that the material directory was not
deployed on the remote Unix server.
So I have the following questions:
- is the material directory deleted at the end of the TestSuite ?
- where is precisely deployed the material directory (I'm wondering
whether I don't have an environement variable conflict somewhere, because
TPTP is creating a [RA_TEMP_DIR]/Administrator/DOCUMEN~1/... on the Unix
machine wherehas in the TestSuite, the material is located in
[RA_TEMP_DIR]/Administrator/com.axway.xtp.connector.tests/as sets/HTTP_Gtw_Xib/material)
- any idea of what else could be the problem ?
Thanks for your help
CG
Re: Deployement of the material [message #108157 is a reply to message #107938] Thu, 09 August 2007 06:53 Go to previous message
Hi CG,
Test dependencies that will be deployed to the remote machine and rooted
under your ROOTDIR should be added to teh CLASSPATH parameter for your
artifact:
http://help.eclipse.org/help32/topic/org.eclipse.hyades.test .doc.user/ref/rdeploymentGroundRules.htm
The following procedure is used to calculate ROOTDIR:
Step 1: TPTP first looks on the remote machine for the ROOTDIR location
property (if specified); if this exists, then its value is taken as the
output from this step.
If the ROOTDIR location property has not been specified, or if it has but
does not exist on the remote machine, TPTP derives one using the temporary
directory found on the remote machine's environment; it looks for
LOCAL_AGENT_TEMP_DIR, TEMP, and TMP, in that order, and, whichever is found
first is taken as the output from this step.
Step 2: TPTP looks for the USR_NAME location property on the local machine.
If this does not exist it pulls the user.name property from Java
(System.getProperty("user.name")).
Step 3: TPTP concatenates the outputs from Steps 1 and 2 and takes this to
be the ROOTDIR to use.
If you still cannot diagnose the problem, please attach your deployment,
artifact and location files to your reply.
Paul
"CG" <cguibert@axway.com> wrote in message
news:47dbfa7fd6658db5e34a249d22128724$1@www.eclipse.org...
> Hello
> Regards
> CG
Previous Topic:TPTP 4.4.0.1 is released!
Next Topic:[TPTP AGR] Path to Logger file in standard mode
Current Time: Sun Nov 09 04:26:16 EST 2025
Powered by FUDForum. Page generated in 0.04330 seconds
