Drill Through To Cascading Parameters [message #1077472] |
Thu, 01 August 2013 15:15  |
I'm having an issue passing two parameters to another report which uses cascading parameters. The values are being passed correctly, as I can see in the URL, but if the combination of the two (level 1 param and level 2 param) are not valid, then the level 2 param gets reset to the default based on the level 1 param. For example, I have a report that shows contract numbers and the contract status (active or inactive). I click the contract to drill down to the detail by customer and pass the contract's status (level 1) and contract ID (level 2). If I pass status:Inactive ID:25 but ID:25 isn't in the currently inactive list, then the contract ID is ignored and is defaulted back to contract ID 1 which is the first inactive contract.
Is there a way to prevent the cascading auto population of the second level parameter when drilling through?
FUDForum. Page generated in 0.05015 seconds
