Home » Eclipse Projects » Sisu » Any specific tutorials/demos you'd like to see?
Any specific tutorials/demos you'd like to see? [message #1076216] Tue, 30 July 2013 20:32 Go to next message
Hi folks,
Now that the API refactoring is done the emphasis is on documentation, and I was
wondering if there are any specific tutorials/demos that you would like to see first?
http://eclipse.org/sisu/docs/tutorials/index.html
Otherwise I'll follow-up the 5 minute tutorial with a more in-depth example that
shows how to create a simple plugin system and dynamically watch for components.
Cheers, Stuart
Re: Any specific tutorials/demos you'd like to see? [message #1238341 is a reply to message #1076216] Fri, 31 January 2014 21:57 Go to previous message
I added an example on the Wiki of adding another module to set up some parameter bindings. That could be a full example.
A unit test using InjectTestCase.
Give the paucity of doc, I confess that I'm not sure what I'd like to know. What else can Sisu do for me?
Previous Topic:Milestone 0.0.0.M5
Next Topic:Sisu repositories have moved to GitHub
Current Time: Sun Jul 20 17:39:46 EDT 2025
Powered by FUDForum. Page generated in 0.03609 seconds
