Home » Eclipse Projects » Remote Application Platform (RAP) » Widget is disposed exception on table when double click
Widget is disposed exception on table when double click [message #1075401] Mon, 29 July 2013 07:08 Go to next message
I've got a "org.eclipse.swt.SWTException: Widget is disposed" when handle a double on swt table. When I use a button there no problem. There is an example as attachment.
Can anybody help.
Thanks Marco.
Re: Widget is disposed exception on table when double click [message #1075417 is a reply to message #1075401] Mon, 29 July 2013 07:35 Go to previous messageGo to next message
Hi Marco,
your snipper works fine for me with RAP from git (master). Which RAP
version are you using? Please post the stack trace.
P.S. One small remark - never catch Throwable in RAP especially when you
run your application in |SWT_COMPATIBILITY| operational mode
<http://help.eclipse.org/juno/topic/org.eclipse.rap.help/help/html/reference/api/org/eclipse/rwt/application/Application.OperationMode.html#SWT_COMPATIBILITY>.
See this blog post:
http://eclipsesource.com/blogs/2012/08/08/to-catch-or-not-to-catch-throwable/
Best,
Ivan
On 7/29/2013 2:08 PM, Marco Feldmann wrote:
> Hello,
> Can anybody help.
> Thanks Marco.
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Widget is disposed exception on table when double click [message #1075429 is a reply to message #1075417] Mon, 29 July 2013 08:16 Go to previous messageGo to next message
Hi Ivan,
thanks for your fast answer and your blog post. I use RAP 2.0. Here is the complete stack trace:
at org.eclipse.swt.SWT.error(SWT.java:3546)
at org.eclipse.swt.SWT.error(SWT.java:3469)
at org.eclipse.swt.SWT.error(SWT.java:3440)
at org.eclipse.swt.widgets.Widget.error(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:969)
at org.eclipse.swt.widgets.Widget.getData(Widget.java:225)
at org.eclipse.jface.viewers.StructuredViewer.handleDoubleSelect(StructuredViewer.java:1109)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1228)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:242)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:239)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:304)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:85)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:696)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:598)
at org.eclipse.swt.widgets.Display.executeNextEvent(Display.java:1172)
at org.eclipse.swt.widgets.Display.runPendingMessages(Display.java:1153)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1143)
at org.eclipse.rap.rwt.internal.lifecycle.ProcessAction.execute(ProcessAction.java:27)
at org.eclipse.rap.rwt.internal.lifecycle.PhaseExecutor.execute(PhaseExecutor.java:35)
at org.eclipse.rap.rwt.internal.lifecycle.SimpleLifeCycle.execute(SimpleLifeCycle.java:51)
at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.runLifeCycle(LifeCycleServiceHandler.java:120)
at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.handlePostRequest(LifeCycleServiceHandler.java:106)
at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.synchronizedService(LifeCycleServiceHandler.java:71)
at org.eclipse.rap.rwt.internal.service.LifeCycleServiceHandler.service(LifeCycleServiceHandler.java:62)
at org.eclipse.rap.rwt.engine.RWTServlet.handleValidRequest(RWTServlet.java:107)
at org.eclipse.rap.rwt.engine.RWTServlet.handleRequest(RWTServlet.java:94)
at org.eclipse.rap.rwt.engine.RWTServlet.doPost(RWTServlet.java:87)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:669)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:457)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:557)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1075)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:384)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1009)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:255)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:368)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:489)
at org.eclipse.jetty.server.BlockingHttpConnection.handleRequest(BlockingHttpConnection.java:53)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:953)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:1014)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:861)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
at org.eclipse.jetty.server.BlockingHttpConnection.handle(BlockingHttpConnection.java:72)
at org.eclipse.jetty.server.bio.SocketConnector$ConnectorEndPoint.run(SocketConnector.java:264)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
at java.lang.Thread.run(Thread.java:722)
Re: Widget is disposed exception on table when double click [message #1075444 is a reply to message #1075429] Mon, 29 July 2013 08:46 Go to previous messageGo to next message
Hello Ivan,
I have the same problem with rap 2.1.
Re: Widget is disposed exception on table when double click [message #1075446 is a reply to message #1075429] Mon, 29 July 2013 08:46 Go to previous messageGo to next message
Hi Marco,
the key point in your snippet is to double click on the last item (which
will be removed). Now I can reproduce it with RAP from git master too.
I've tested your snippet in RCP and it's working fine there. Please open
a bugzilla and we will investigate the issue.
Ivan
On 7/29/2013 3:17 PM, Marco Feldmann wrote:
> Hi Ivan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Ivan Furnadjiev
Re: Widget is disposed exception on table when double click [message #1075454 is a reply to message #1075446] Mon, 29 July 2013 09:03 Go to previous messageGo to next message
OK... here are my findings after short investigation. When you doble
click on the last item (which will be removed), two events are sent from
the client - widgetDefaultSelected and mouseDoubleClick. Mouse double
click listener is executed on the server first and item is disposed. As
a result, (default) selection listener is executed with already disposed
item. Probably we need a dispose check in
StructuredViewer.handleDoubleSelect:
if (event.item != null && !event.item.isDisposed() &&
event.item.getData() != null) {
Best,
Ivan
On 7/29/2013 3:46 PM, Ivan Furnadjiev wrote:
> Hi Marco,
> (which will be removed). Now I can reproduce it with RAP from git
> master too. I've tested your snippet in RCP and it's working fine
> there. Please open a bugzilla and we will investigate the issue.
> Ivan
>> Hi Ivan,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Ivan Furnadjiev
Re: Widget is disposed exception on table when double click [message #1075463 is a reply to message #1075454] Mon, 29 July 2013 09:19 Go to previous messageGo to next message
Hello Ivan,
thats fine. When will you fix it?
Re: Widget is disposed exception on table when double click [message #1075467 is a reply to message #1075463] Mon, 29 July 2013 09:28 Go to previous messageGo to next message
Hi Marco,
please file a bugzilla to track the progress.
Ivan
On 7/29/2013 4:19 PM, Marco Feldmann wrote:
> Hello Ivan,
Ivan Furnadjiev
Re: Widget is disposed exception on table when double click [message #1075482 is a reply to message #1075467] Mon, 29 July 2013 09:59 Go to previous message
Ivan Furnadjiev wrote on Mon, 29 July 2013 09:28
Hi Marco,
Ivan
Done. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=413920
Previous Topic:Selenium get Widget by DOM Element
Next Topic:Popup Menu can be used in RAP?
Current Time: Sat Jul 26 11:57:48 EDT 2025
Powered by FUDForum. Page generated in 0.08111 seconds
