Home » Eclipse Projects » Nebula » XViewer Depth First Search Filter and CustomizeManager(Don't filter out parent element if children match)
XViewer Depth First Search Filter and CustomizeManager [message #1071218] Fri, 19 July 2013 11:23 Go to next message
I would like XViewer to support a depth first search algorithm. In that if any of the children match it should also match the parent.
I accomplished this by overriding the getXViewerTextFilter method in my XViewer and returning an XViewer with following select method:
public boolean select(Viewer viewer, Object parentElement, Object element) {
		ITreeContentProvider cp = (ITreeContentProvider) this.xViewer.getContentProvider();
		boolean retVal = super.select(viewer, parentElement, element);
		if (retVal) {
			return true;
		if (cp.hasChildren(element)) {
			for (Object child : cp.getChildren(element)) {
				retVal = select(viewer, element, child);
				if (retVal) {
					break;
		return retVal;
This seems to work. Is there a better method?
Also, I'd like it to automatically expand to show all matching children. Unfortunately, it looks like to do this I would need to change the behavior of the CustomizeManager in the setFilterText method to do:
xViewer.expandAll();
At the end of the method. However, there is no way to provide my own implementation of the CustomizeManager as it is a private field created in the constructor of the XViewer. Suggestions? It would be nice if the XViewerFactory provided a mechanism to provide my own CustomizeManager.
Thanks.
Re: XViewer Depth First Search Filter and CustomizeManager [message #1430391 is a reply to message #1071218] Wed, 24 September 2014 06:21 Go to previous message
Thanks for the code. It help's me.
Do you find the solution to own implementation of the CustomizeManager?
I found a workaround I am not sure, it is the right way.
In the my XViewer, override the refresh method as follow
  public void refresh() {
    super.refresh();
    if (getCustomizeMgr().getFilterText().isEmpty()) {
     // This is collapse entire tree when no filter is applied
      collapseAll();
    else {
      expandAll();
Please let me know if this is right approach Smile
BR
Ramukumar M
[Updated on: Wed, 24 September 2014 06:38] by Moderator
Previous Topic:Grid with Row header problems viewing last column group
Next Topic:GanttChart Event Position after zoom
Current Time: Thu Jul 24 02:38:14 EDT 2025
Powered by FUDForum. Page generated in 0.03033 seconds
