Home » Archived » Hudson » Deployment problem on GlassFish 4
Deployment problem on GlassFish 4 [message #1068764] Sun, 14 July 2013 05:25 Go to next message
Hi everyone,
I've just tried to deploy Hudson 3.0.1 on GlassFish 4, and the deployment ended up with the following log messages:
[2013-07-14T05:22:17.632+0400] [glassfish 4.0] [INFO] [] [org.glassfish.admingui] [tid: _ThreadID=36 _ThreadName=admin-listener(4)] [timeMillis: 1373764937632] [levelValue: 800] [[
  GUI deployment: uploadToTempfile]]
[2013-07-14T05:22:17.681+0400] [glassfish 4.0] [INFO] [] [org.glassfish.admingui] [tid: _ThreadID=36 _ThreadName=admin-listener(4)] [timeMillis: 1373764937681] [levelValue: 800] [[
  uploadFileName=hudson-3.0.1.war]]
[2013-07-14T05:22:56.460+0400] [glassfish 4.0] [INFO] [] [javax.enterprise.system.tools.deployment.common] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764976460] [levelValue: 800] [[
  visiting unvisited references]]
[2013-07-14T05:23:07.136+0400] [glassfish 4.0] [INFO] [] [org.jboss.weld.Version] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764987136] [levelValue: 800] [[
  WELD-000900 2.0.0 (SP1)]]
[2013-07-14T05:23:08.852+0400] [glassfish 4.0] [WARNING] [] [org.glassfish.weld.BeanDeploymentArchiveImpl] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764988852] [levelValue: 900] [[
  AS-CDI-005]]
[2013-07-14T05:23:19.286+0400] [glassfish 4.0] [WARNING] [] [org.jboss.weld.interceptor.util.InterceptionTypeRegistry] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764999286] [levelValue: 900] [[
  Class 'javax.ejb.PostActivate' not found, interception based on it is not enabled]]
[2013-07-14T05:23:19.288+0400] [glassfish 4.0] [WARNING] [] [org.jboss.weld.interceptor.util.InterceptionTypeRegistry] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764999288] [levelValue: 900] [[
  Class 'javax.ejb.PrePassivate' not found, interception based on it is not enabled]]
[2013-07-14T05:23:19.982+0400] [glassfish 4.0] [SEVERE] [NCLS-CORE-00026] [javax.enterprise.system.core] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764999982] [levelValue: 1000] [[
  Exception during lifecycle processing
org.glassfish.deployment.common.DeploymentException: CDI deployment failure:Exception List with 2 exceptions:
Exception 0 :
org.jboss.weld.exceptions.DeploymentException: WELD-001408 Unsatisfied dependencies for type [Injector] with qualifiers [@Default] at injection point [[BackedAnnotatedField] @Inject private org.sonatype.guice.bean.binders.TypeConverterMap.injector]
	at org.jboss.weld.bootstrap.Validator.validateInjectionPointForDeploymentProblems(Validator.java:403)
	at org.jboss.weld.bootstrap.Validator.validateInjectionPoint(Validator.java:325)
	at org.jboss.weld.bootstrap.Validator.validateGeneralBean(Validator.java:177)
	at org.jboss.weld.bootstrap.Validator.validateRIBean(Validator.java:208)
	at org.jboss.weld.bootstrap.Validator.validateBean(Validator.java:519)
	at org.jboss.weld.bootstrap.Validator.validateBeans(Validator.java:505)
	at org.jboss.weld.bootstrap.Validator.validateDeployment(Validator.java:480)
	at org.jboss.weld.bootstrap.WeldBootstrap.validateBeans(WeldBootstrap.java:536)
	at org.glassfish.weld.WeldDeployer.event(WeldDeployer.java:216)
	at org.glassfish.kernel.event.EventsImpl.send(EventsImpl.java:131)
	at org.glassfish.internal.data.ApplicationInfo.load(ApplicationInfo.java:328)
	at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:493)
	at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:219)
	at org.glassfish.deployment.admin.DeployCommand.execute(DeployCommand.java:491)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:527)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:523)
	at javax.security.auth.Subject.doAs(Subject.java:356)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl$2.execute(CommandRunnerImpl.java:522)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:546)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:1423)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl.access$1500(CommandRunnerImpl.java:108)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1762)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1674)
	at org.glassfish.admin.rest.utils.ResourceUtil.runCommand(ResourceUtil.java:235)
	at org.glassfish.admin.rest.utils.ResourceUtil.runCommand(ResourceUtil.java:257)
	at org.glassfish.admin.rest.resources.TemplateListOfResource.createResource(TemplateListOfResource.java:134)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81)
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:125)
	at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:152)
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:91)
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:346)
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:341)
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:101)
	at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:224)
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271)
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267)
	at org.glassfish.jersey.internal.Errors.process(Errors.java:315)
	at org.glassfish.jersey.internal.Errors.process(Errors.java:297)
	at org.glassfish.jersey.internal.Errors.process(Errors.java:267)
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317)
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:198)
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:946)
	at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:331)
	at org.glassfish.admin.rest.adapter.RestAdapter$2.service(RestAdapter.java:318)
	at org.glassfish.admin.rest.adapter.RestAdapter.service(RestAdapter.java:181)
	at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:246)
	at org.glassfish.grizzly.http.server.HttpHandler.runService(HttpHandler.java:191)
	at org.glassfish.grizzly.http.server.HttpHandler.doHandle(HttpHandler.java:168)
	at org.glassfish.grizzly.http.server.HttpServerFilter.handleRead(HttpServerFilter.java:189)
	at org.glassfish.grizzly.filterchain.ExecutorResolver$9.execute(ExecutorResolver.java:119)
	at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeFilter(DefaultFilterChain.java:288)
	at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeChainPart(DefaultFilterChain.java:206)
	at org.glassfish.grizzly.filterchain.DefaultFilterChain.execute(DefaultFilterChain.java:136)
	at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:114)
	at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:77)
	at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:838)
	at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:113)
	at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.run0(WorkerThreadIOStrategy.java:115)
	at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.access$100(WorkerThreadIOStrategy.java:55)
	at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy$WorkerThreadRunnable.run(WorkerThreadIOStrategy.java:135)
	at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:564)
	at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:544)
	at java.lang.Thread.run(Thread.java:724)
Exception 0 :
org.jboss.weld.exceptions.DeploymentException: WELD-001408 Unsatisfied dependencies for type [Injector] with qualifiers [@Default] at injection point [[BackedAnnotatedParameter] Parameter 1 of [BackedAnnotatedMethod] @Inject org.sonatype.guice.bean.locators.DefaultBeanLocator.autoPublish(Injector)]
	at org.glassfish.weld.WeldDeployer.event(WeldDeployer.java:225)
Caused by: org.jboss.weld.exceptions.DeploymentException: Exception List with 2 exceptions:
Exception 0 :
Exception 0 :
	at org.jboss.weld.bootstrap.Validator.validateBeans(Validator.java:511)
	... 59 more
[2013-07-14T05:23:19.985+0400] [glassfish 4.0] [SEVERE] [] [javax.enterprise.system.core] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764999985] [levelValue: 1000] [[
  Exception while loading the app]]
As far as I can tell, there's some trouble with injecting of dependencies, i. e. CDI subsystem. I'm not experienced in this matter, so any hints on the source of the problem will be appreciated a lot.
Thanks in advance,
Roman
Re: Deployment problem on GlassFish 4 [message #1068914 is a reply to message #1068764] Sun, 14 July 2013 14:31 Go to previous messageGo to next message
For some bizarre reason JSR346 (implemented by CDI 1.1 bundled with GlassFish 4) made the decision to treat any class that has a constructor annotated with @Inject as a JEE managed bean. This is contrary to JSR330 which defines @Inject as purely an identifier of injectable constructors, methods, and fields. Unfortunately this means that any JSR330 annotated class will be interpreted as a managed bean in GlassFish 4 even though it was not originally written as such. This is why you see the above errors and why the deployment eventually fails. This could have been avoided if JSR346 and CDI 1.1 had not chosen to arbitrarily assume that classes with @Inject constructors are managed beans - or if they'd decided to log issues with such classes (caused by mis-intepreting them as managed beans) as warnings and not errors.
AFAIK the only workaround is to add a beans.xml to the WAR's WEB-INF directory with the following content:
<beans xmlns="http://xmlns.jcp.org/xml/ns/javaee"
    xsi:schemaLocation="http://xmlns.jcp.org/xml/ns/javaee http://xmlns.jcp.org/xml/ns/javaee/beans_1_1.xsd"
    bean-discovery-mode="none">
  This file is here for bean-discovery-mode="none", which turns off CDI 1.1's erroneous behaviour
  of assuming that anything annotated with @Inject is a "managed bean" and must be instantiated
</beans>
Re: Deployment problem on GlassFish 4 [message #1068916 is a reply to message #1068914] Sun, 14 July 2013 14:37 Go to previous messageGo to next message
See https://code.google.com/p/guava-libraries/issues/detail?id=1433 for the same issue with other libraries/applications
Re: Deployment problem on GlassFish 4 [message #1068944 is a reply to message #1068914] Sun, 14 July 2013 16:47 Go to previous messageGo to next message
Seems that the GlassFish code to turn off the implicit CDI detection is also buggy - neither the application-wide beans.xml or the implicitCdiEnabled property mentioned in https://java.net/jira/browse/GLASSFISH-20579 were respected.
The only setting that I could get to work was:
asadmin set configs.config.server-config.cdi-service.enable-implicit-cdi=false
After setting this I was able to deploy the vanilla hudson WAR file.
Re: Deployment problem on GlassFish 4 [message #1068998 is a reply to message #1068944] Sun, 14 July 2013 20:05 Go to previous messageGo to next message
http://cdi-specification-discussions.1064426.n5.nabble.com/Doubt-about-bean-discovery-default-behaviour-tt5708903.html has more detail on the behaviour change from CDI 1.0 to 1.1 - apparently GlassFish 4 treats @Singleton as a "bean defining annotation" which seems odd and they're looking at fixing this, until then turning off implicit CDI scanning is the recommended workaround.
Re: Deployment problem on GlassFish 4 [message #1069351 is a reply to message #1068764] Mon, 15 July 2013 14:12 Go to previous message
Stuart,
thank you for the detailed information and useful links!
I managed to deploy Hudson using this setting you've mentioned:
It seems like GlassFish 4 is misconfigured in respect of CDI 1.1 by default.
Previous Topic:Hudson / Artifactory problem
Next Topic:Configuring Multiple Hudson Instances
Current Time: Sun Sep 21 13:59:44 EDT 2025
Powered by FUDForum. Page generated in 0.03788 seconds
