Home » Eclipse Projects » Rich Client Platform (RCP) » Jetty Disables OSGi Services
Jetty Disables OSGi Services [message #1067287] Mon, 08 July 2013 04:20 Go to next message
Hello!
I'm managing a bunch of RCP plug-ins that rely heavily on OSGi services (e.g. for single sourcing with RAP). Now I thought it might be a good idea to integrate the Eclipse help plug-in, but whenever I add the Jetty plug-ins, the services will vanish.
So I have two short questions: Why? And how can I get both OSGi services and Eclipse help to work?
(I thought about adding a demo project, but the mailapp already contains everything. Just add a service and it will disappear once "org.eclipse.help.ui", "org.eclipse.help.webapp" and "org.eclipse.equinox.http.jetty" are added to the launch configuration.)
Thanks in advance!
S. Schulz
Edit: After testing a bit more, it seems possible that Equinox is the culprit, not just Jetty.
[Updated on: Mon, 08 July 2013 04:52] by Moderator
Re: Jetty Disables OSGi Services [message #1067332 is a reply to message #1067287] Mon, 08 July 2013 06:35 Go to previous messageGo to next message
I've been entirely wrong, it's neither Jetty nor Equinox, but the plug-in "org.eclipse.update.configurator". Starting this plug-in will make all the OSGi services disappear, disabling it will make them reappear. I'd love to hear something regarding the question: Why?
Re: Jetty Disables OSGi Services [message #1067594 is a reply to message #1067287] Tue, 09 July 2013 09:50 Go to previous messageGo to next message
Could this be related to this issue: https://bugs.eclipse.org/bugs/show_bug.cgi?format=multiple&id=344414 ?
Re: Jetty Disables OSGi Services [message #1067689 is a reply to message #1067594] Wed, 10 July 2013 03:01 Go to previous message
Yes, you are entirely right. Luckily we don't need the "org.eclipse.update.configurator", so removing it after each "Add Required Bundles" will do the trick. Thank you!
Previous Topic:IWorkbenchPage.getPartState() always returns RESTORED
Next Topic:How to deal with command framework and MasterDetailsBlock
Current Time: Sat Jul 19 19:43:34 EDT 2025
Powered by FUDForum. Page generated in 0.23729 seconds
