Home » Eclipse Projects » Mylyn » Gerrit versions
Gerrit versions [message #1064674] Thu, 20 June 2013 09:47 Go to next message
I plan to upgrade to Eclipse 4.3 (after it gets released) and start using Gerrit + Jenkins + Mylyn.
I'm not sure, which version of Gerrit should I use. In the "new and noteworthy" of Mylyn Gerrit adapter I found, that only versions 2.3 and 2.4 are supported. On the Gerrit website the version 2.4 isn't even there for download.
Which version of Gerrit should I choose in order to get most stable configuration?
Thank you!
Kind regards,
Boris Brodski
Re: Gerrit versions [message #1066388 is a reply to message #1064674] Tue, 02 July 2013 08:03 Go to previous messageGo to next message
Hi Boris,
The best option for now would be using 2.5.x as we struggling to enable support for the latest 2.6, see bug 395059. This should be fixed in an upcoming release.
T
Re: Gerrit versions [message #1066394 is a reply to message #1066388] Tue, 02 July 2013 08:21 Go to previous message
Hello Thomasz,
thank you! I will stick with 2.5.x for a while then.
Boris
Previous Topic:Subtasks ghosted (grayed out)
Next Topic:Mylyn Reviews can't connect to https://git.eclipse.org/r
Current Time: Mon Jun 16 04:44:18 EDT 2025
Powered by FUDForum. Page generated in 0.24098 seconds
