Home » Archived » BIRT » Birt viewer 4.3 PPTX
Birt viewer 4.3 PPTX [message #1065923] Fri, 28 June 2013 06:42 Go to next message
i tested the new DOCX and PPTX export functionality, it works almost correct because i have a problem, but only in PPTX, on strings of text: the text is splitted into several text boxes.
This to me is a problem in fact customers would like to change the text.
There is a way to create in PPTX a single text box as well as DOCX?
Thanks in advance
Re: Birt viewer 4.3 PPTX [message #1066137 is a reply to message #1065923] Mon, 01 July 2013 04:14 Go to previous messageGo to next message
No solution for this problem?
Re: Birt viewer 4.3 PPTX [message #1066893 is a reply to message #1066137] Fri, 05 July 2013 01:43 Go to previous messageGo to next message
Sorry for the delay. I think this is the same as it worked in the other emitter as well. This is likely something you'll have to create an enhancement request for. You'd do this in the bugzilla.
Re: Birt viewer 4.3 PPTX [message #1067276 is a reply to message #1066893] Mon, 08 July 2013 04:00 Go to previous messageGo to next message
Hi Micahel,
no problem for the answer; what should I do to enter the request in bugzilla? How it works (someone reporting me when the task is closed)?
Thanks in advance
Re: Birt viewer 4.3 PPTX [message #1067719 is a reply to message #1067276] Wed, 10 July 2013 05:42 Go to previous messageGo to next message
Mimmo Rossi wrote on Mon, 08 July 2013 04:00
Hi Micahel,
Thanks in advance
Hi Michael,
i added a bug in bugzilla that have this id 412493; but what should I do? I have to check it every day or receive some feedback?
[Updated on: Wed, 10 July 2013 05:42] by Moderator
Re: Birt viewer 4.3 PPTX [message #1068297 is a reply to message #1067719] Fri, 12 July 2013 18:43 Go to previous messageGo to next message
Yeah. When anyone does anything on the bug, you should get an email notification. If you post the bug info in here and others with the same issue stumble across it, they can vote for the bug. Typically the bugs with the most votes get attention along with the critical bugs.
Re: Birt viewer 4.3 PPTX [message #1076403 is a reply to message #1068297] Wed, 31 July 2013 06:35 Go to previous messageGo to next message
Hi Michael,
i monitor a bug, but its status is Always NEW; i can do something to "highlight" this bug?
In addition to the id of the bug, already indicated, now i insert a link to this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=412493
Do you think it's enough?
Re: Birt viewer 4.3 PPTX [message #1078516 is a reply to message #1076403] Sat, 03 August 2013 01:18 Go to previous messageGo to next message
Usually the bugs with the most votes get looked at the quickest. You might also post an example so it's easy for them to look at once they do get to your post.
Re: Birt viewer 4.3 PPTX [message #1079886 is a reply to message #1078516] Mon, 05 August 2013 03:48 Go to previous message
Hi Michael
thanks for your tip, i will insert an example of pptx and doc.
Previous Topic:Barcodes ?
Next Topic:Paint area in Line Chart
Current Time: Wed Jul 23 07:46:41 EDT 2025
Powered by FUDForum. Page generated in 0.06393 seconds
