Home » Modeling » TMF (Xtext) » Error "Failed to create injector"
icon3.gif  Error "Failed to create injector" [message #1063742] Fri, 14 June 2013 00:55 Go to next message
Hello every one,
I used xtext to create an editor for power loom using this grammar file:
code.google.com/a/eclipselabs.org/p/pl-editor/source/browse/ru.agentlab.powerloom.tool/src/ru/agentlab/powerloom/tool/PowerLoom.xtext?spec=svndc8a3d498c6d145f0adb6c509c131063420e3f0a&r=dc8a3d498c6d145f0adb6c509c131063420e3f0a
and it works with out any problem when I tested the project as eclipse application.
then I created an "Update site project" and added the feature "My Editor.sdk" and add it to a new eclipse.
but I got this error when I tried to open a file using this editor
Failed to create injector for de.tuc.in.sse.powerloom.tool.xtext.PowerLoom ExtensionFactory: de.tuc.in.sse.powerloom.tool.xtext.ui.PowerLoomExecutableExtensionFactory
Details:
org.eclipse.core.runtime.CoreException: Failed to create injector for de.tuc.in.sse.powerloom.tool.xtext.PowerLoom ExtensionFactory: de.tuc.in.sse.powerloom.tool.xtext.ui.PowerLoomExecutableExtensionFactory
	at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:57)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:273)
	at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:269)
	at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:235)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:319)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:262)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPart(CompatibilityEditor.java:61)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:299)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:861)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:841)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:113)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:321)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:242)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:894)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:629)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:731)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:702)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:696)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:681)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1115)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:641)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:520)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:505)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:74)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:644)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:987)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.RuntimeException: Failed to create injector for de.tuc.in.sse.powerloom.tool.xtext.PowerLoom
	at de.tuc.in.sse.powerloom.tool.xtext.ui.internal.PowerLoomActivator.createInjector(PowerLoomActivator.java:71)
	at de.tuc.in.sse.powerloom.tool.xtext.ui.internal.PowerLoomActivator.getInjector(PowerLoomActivator.java:55)
	at de.tuc.in.sse.powerloom.tool.xtext.ui.PowerLoomExecutableExtensionFactory.getInjector(PowerLoomExecutableExtensionFactory.java:26)
	at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:49)
	... 128 more
Caused by: com.google.inject.CreationException: Guice creation errors:
1) No implementation for org.eclipse.jface.viewers.ILabelProvider was bound.
  at org.eclipse.xtext.ui.DefaultUiModule.configureContentProposalLabelProvider(DefaultUiModule.java:275)
2) No implementation for org.eclipse.jface.viewers.ILabelProvider was bound.
  at org.eclipse.xtext.ui.DefaultUiModule.configureHyperlinkLabelProvider(DefaultUiModule.java:246)
3) No implementation for org.eclipse.xtext.ui.editor.quickfix.IssueResolutionProvider was bound.
  while locating org.eclipse.xtext.ui.editor.quickfix.IssueResolutionProvider
    for field at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.issueResolutionProvider(Unknown Source)
  while locating com.google.inject.Provider<org.eclipse.xtext.ui.editor.model.XtextDocumentProvider>
    for field at org.eclipse.xtext.ui.editor.XtextEditor.documentProvider(Unknown Source)
  while locating com.google.inject.Provider<org.eclipse.xtext.ui.compare.DefaultMergeEditor>
    for field at org.eclipse.xtext.ui.compare.DefaultViewerCreator.mergeEditorProvider(Unknown Source)
  at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:55)
4) No implementation for org.eclipse.jface.viewers.ILabelProvider was bound.
  while locating org.eclipse.jface.viewers.ILabelProvider
    for field at org.eclipse.xtext.ui.editor.outline.impl.DefaultOutlineTreeProvider.labelProvider(Unknown Source)
  while locating org.eclipse.xtext.ui.editor.outline.IOutlineTreeProvider
    for field at org.eclipse.xtext.ui.editor.outline.impl.OutlinePage.treeProvider(Unknown Source)
5) No implementation for org.eclipse.xtext.ui.editor.quickfix.IssueResolutionProvider was bound.
    for field at org.eclipse.xtext.ui.editor.quickfix.AbstractIssueResolutionProviderAdapter.resolutionProvider(Unknown Source)
  while locating org.eclipse.xtext.ui.editor.quickfix.XtextQuickAssistProcessor
    for parameter 0 at org.eclipse.xtext.ui.editor.quickfix.XtextQuickAssistAssistant.<init>(Unknown Source)
  while locating com.google.inject.Provider<org.eclipse.xtext.ui.editor.quickfix.XtextQuickAssistAssistant>
    for field at org.eclipse.xtext.ui.editor.XtextSourceViewerConfiguration.quickAssistAssistentProvider(Unknown Source)
  while locating org.eclipse.xtext.ui.editor.XtextSourceViewerConfiguration
    for field at org.eclipse.xtext.ui.compare.DefaultContentViewer.sourceViewerConfiguration(Unknown Source)
  while locating com.google.inject.Provider<org.eclipse.xtext.ui.compare.DefaultContentViewer>
    for field at org.eclipse.xtext.ui.compare.DefaultViewerCreator.contentViewerProvider(Unknown Source)
6) No implementation for org.eclipse.xtext.ui.editor.quickfix.IssueResolutionProvider was bound.
    for field at org.eclipse.xtext.ui.editor.XtextEditor.sourceViewerConfiguration(Unknown Source)
7) No implementation for org.eclipse.xtext.ui.editor.quickfix.IssueResolutionProvider was bound.
  while locating com.google.inject.Provider<org.eclipse.xtext.ui.editor.XtextSourceViewerConfiguration>
    for field at org.eclipse.xtext.ui.compare.DefaultViewerCreator.sourceViewerConfigurationProvider(Unknown Source)
8) No implementation for org.eclipse.xtext.ui.editor.quickfix.IssueResolutionProvider was bound.
    for field at org.eclipse.xtext.ui.editor.hover.AnnotationWithQuickFixesHover.quickAssistProcessor(Unknown Source)
  while locating org.eclipse.xtext.ui.editor.hover.AnnotationWithQuickFixesHover
    for field at org.eclipse.xtext.ui.editor.hover.DefaultCompositeHover.annotationHover(Unknown Source)
8 errors
	at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:435)
	at com.google.inject.internal.InternalInjectorCreator.initializeStatically(InternalInjectorCreator.java:154)
	at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:106)
	at com.google.inject.Guice.createInjector(Guice.java:95)
	at com.google.inject.Guice.createInjector(Guice.java:72)
	at com.google.inject.Guice.createInjector(Guice.java:62)
	at de.tuc.in.sse.powerloom.tool.xtext.ui.internal.PowerLoomActivator.createInjector(PowerLoomActivator.java:67)
	... 131 more
any help
thanks in advanced
Re: Error "Failed to create injector" [message #1063964 is a reply to message #1063742] Sun, 16 June 2013 18:17 Go to previous messageGo to next message
Thanks, I fix it
Re: Error "Failed to create injector" [message #1066000 is a reply to message #1063964] Fri, 28 June 2013 14:12 Go to previous messageGo to next message
could you please share your solution with the community, that would be great.
Thanks!
Robert
[Updated on: Fri, 28 June 2013 14:12] by Moderator
Re: Error "Failed to create injector" [message #1066042 is a reply to message #1066000] Sat, 29 June 2013 05:51 Go to previous messageGo to next message
In my case, the problem was that I forgot to add the "xtend-gen" folder to the build.properties in my ui-project, where I did some extensions using Xtend. So, in the product I exported, the Java classes that are automatically derived from my custom Xtend implementations where missing, so Guice failed to create injectors I use there.
Since, in my IDE the xtend-gen folder belongs to the classpath anyway, the problem did not occur when starting the product/plugin there.
Re: Error "Failed to create injector" [message #1770258 is a reply to message #1066042] Wed, 09 August 2017 08:56 Go to previous messageGo to next message
I have added the xtend-gen in my build.properties file as well but I am still getting a similar error for my language. Please help find me find the issue. Here is the exception I have got.
org.eclipse.core.runtime.CoreException: Failed to create injector for com.amadeus.secomo.siteparameters.SiteParameterLanguage ExtensionFactory: com.amadeus.secomo.siteparameters.ui.SiteParameterLanguageExecutableExtensionFactory
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:59)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:282)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:329)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:278)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPart(CompatibilityEditor.java:63)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:316)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:104)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4821)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:617)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:581)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:770)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1214)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3261)
at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3176)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3158)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3153)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3117)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3107)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:563)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:518)
at org.eclipse.ui.wizards.newresource.BasicNewFileResourceWizard.performFinish(BasicNewFileResourceWizard.java:103)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:790)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:423)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:618)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at org.eclipse.ui.internal.actions.NewWizardShortcutAction.run(NewWizardShortcutAction.java:133)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
Caused by: java.lang.RuntimeException: Failed to create injector for com.amadeus.secomo.siteparameters.SiteParameterLanguage
at com.amadeus.secomo.siteparameters.ui.internal.SiteparametersActivator.createInjector(SiteparametersActivator.java:71)
at com.amadeus.secomo.siteparameters.ui.internal.SiteparametersActivator.getInjector(SiteparametersActivator.java:55)
at com.amadeus.secomo.siteparameters.ui.SiteParameterLanguageExecutableExtensionFactory.getInjector(SiteParameterLanguageExecutableExtensionFactory.java:24)
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:51)
... 105 more
1) Error injecting constructor, org.eclipse.emf.common.util.WrappedException: java.lang.ArrayIndexOutOfBoundsException: 4
at com.amadeus.secomo.siteparameters.services.SiteParameterLanguageGrammarAccess.<init>(Unknown Source)
at com.amadeus.secomo.siteparameters.services.SiteParameterLanguageGrammarAccess.class(Unknown Source)
while locating com.amadeus.secomo.siteparameters.services.SiteParameterLanguageGrammarAccess
while locating org.eclipse.xtext.IGrammarAccess
for field at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.grammarAccess(Unknown Source)
at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:57)
while locating org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar
Caused by: org.eclipse.emf.common.util.WrappedException: java.lang.ArrayIndexOutOfBoundsException: 4
at org.eclipse.xtext.parser.BaseEPackageAccess.loadResource(BaseEPackageAccess.java:57)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadGrammarFile(BaseEPackageAccess.java:44)
at org.eclipse.xtext.service.GrammarProvider.getGrammar(GrammarProvider.java:61)
at com.amadeus.secomo.siteparameters.services.SiteParameterLanguageGrammarAccess.internalFindGrammar(SiteParameterLanguageGrammarAccess.java:979)
at com.amadeus.secomo.siteparameters.services.SiteParameterLanguageGrammarAccess.<init>(SiteParameterLanguageGrammarAccess.java:933)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.google.inject.internal.DefaultConstructionProxyFactory$1.newInstance(DefaultConstructionProxyFactory.java:85)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:85)
at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:254)
at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1031)
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
at com.google.inject.Scopes$1$1.get(Scopes.java:65)
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:40)
at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:54)
at com.google.inject.internal.SingleFieldInjector.inject(SingleFieldInjector.java:53)
at com.google.inject.internal.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:110)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:94)
at com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:204)
at com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:198)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1024)
at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:198)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:179)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:109)
at com.amadeus.secomo.siteparameters.ui.internal.SiteparametersActivator.createInjector(SiteparametersActivator.java:67)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 4
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.getEStructuralFeatureData(BinaryResourceImpl.java:2125)
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadEObject(BinaryResourceImpl.java:2521)
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadFeatureValue(BinaryResourceImpl.java:2545)
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadEObject(BinaryResourceImpl.java:2522)
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadEObjects(BinaryResourceImpl.java:2222)
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadFeatureValue(BinaryResourceImpl.java:2555)
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadResource(BinaryResourceImpl.java:2205)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:219)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:265)
at org.eclipse.xtext.resource.SynchronizedXtextResourceSet.getResource(SynchronizedXtextResourceSet.java:25)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadResource(BaseEPackageAccess.java:52)
... 144 more
2) Error injecting constructor, org.eclipse.emf.common.util.WrappedException: java.lang.ArrayIndexOutOfBoundsException: 4
for parameter 0 at org.eclipse.xtext.ui.editor.templates.XtextTemplateContextTypeRegistry.<init>(Unknown Source)
at org.eclipse.xtext.ui.editor.templates.XtextTemplateContextTypeRegistry.class(Unknown Source)
while locating org.eclipse.xtext.ui.editor.templates.XtextTemplateContextTypeRegistry
while locating org.eclipse.jface.text.templates.ContextTypeRegistry
for field at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.contextTypeRegistry(Unknown Source)
at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:38)
at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:62)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:84)
... 154 more
3) Error injecting method, java.lang.NullPointerException
at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.register(Unknown Source)
at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.register(LanguageRegistrar.java:45)
at com.google.inject.internal.SingleMethodInjector$1.invoke(SingleMethodInjector.java:71)
at com.google.inject.internal.SingleMethodInjector.inject(SingleMethodInjector.java:90)
3 errors
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:183)
... 108 more
Re: Error "Failed to create injector" [message #1770390 is a reply to message #1770258] Thu, 10 August 2017 12:06 Go to previous messageGo to next message
i have no idea what could cause this.
can you share a reproducible example?
Re: Error "Failed to create injector" [message #1771031 is a reply to message #1770390] Mon, 21 August 2017 07:31 Go to previous messageGo to next message
[Solved]
I found the error. I had the issue because I failed to include the xtext dependency during the plugin generation. I had to add the dependency while building the plugin or atleast installed the xtext version i used in the new IDE i was using.
Re: Error "Failed to create injector" [message #1871073 is a reply to message #1771031] Fri, 13 September 2024 08:51 Go to previous message
Encountered the same issue. Above mentioned solutions didn't resolve my issue but closing Eclipse, removing the .metadata folder from the workspace resolved the issue.
Apparently, something was stuck in the cache.
Please note that this is a rather brute force solution because by removing the metadata also removes Eclipse workspace settings. For instance, Eclipse started with the Welcome panel and I had to reopen the projects from the workspace.
Previous Topic:Splitting grammar in multiple files, not projects
Next Topic:absolute paths in ._trace files
Current Time: Sat Jul 26 20:20:39 EDT 2025
Powered by FUDForum. Page generated in 0.41035 seconds
