Home » Eclipse Projects » Mylyn » Mylyn Reviews can't connect to https://git.eclipse.org/r
Mylyn Reviews can't connect to https://git.eclipse.org/r [message #1064899] Fri, 21 June 2013 10:49 Go to next message
I failed to connect to https://git.eclipse.org/r with my committer id and http password (as specified in gerrit > settings > http password. I always get "Unable to login to https://git.eclipse.org/r. Please validate credentials via Task Repositories view."
Anonymous login, however, works. Is there any chance I see more of the error message in some logs somewhere?
For our own installations (Gerrit 2.4 and Gerrit 2.5) login via open id works like a charm. Any ideas which configuration step I may have missed or done wrong?
Marcel
[Updated on: Fri, 21 June 2013 10:52] by Moderator
Re: Mylyn Reviews can't connect to https://git.eclipse.org/r [message #1065331 is a reply to message #1064899] Tue, 25 June 2013 06:56 Go to previous messageGo to next message
Hi Marcel,
the Gerrit installation on Eclipse.org was just upgraded to version 2.6 which isn't yet fully supported by Mylyn. We are working on it and hope to add support for 2.6 in an upcoming release:
395059: support Gerrit 2.6 / Eclipse.org Reviews
https://bugs.eclipse.org/bugs/show_bug.cgi?id=395059
Steffen
Re: Mylyn Reviews can't connect to https://git.eclipse.org/r [message #1065339 is a reply to message #1065331] Tue, 25 June 2013 07:13 Go to previous messageGo to next message
Thx. Standing by to test it when ready.
Re: Mylyn Reviews can't connect to https://git.eclipse.org/r [message #1087405 is a reply to message #1065339] Thu, 15 August 2013 11:40 Go to previous messageGo to next message
Hi Steffen,
Today I've tried the Eclipse Gerrit connection and it worked for me after updating my Mylyn/Gerrit connector.
However, I identify some authoring failures yet. Basically the Review editor doesn't allow me to modify the code review state(assign reviewers, publish comments, etc). It looks like I was no authored to do so, so I can only do read-only operations like see attributes, open the compare-editor on patch set files, etc.
Have you received any issue related to this? May I be missing some other configuration bit ? (I've properly set my credentials in the Task Repository view), otherwise should I raise a bugzilla ?
Adolfo.
Re: Mylyn Reviews can't connect to https://git.eclipse.org/r [message #1099848 is a reply to message #1087405] Mon, 02 September 2013 05:54 Go to previous messageGo to next message
Hi Adolfo,
Have you tried the latest version of the connector from Mylyn weekly update site? I've been using that for a while now and it works fine for me.
Tomasz
Re: Mylyn Reviews can't connect to https://git.eclipse.org/r [message #1122692 is a reply to message #1099848] Tue, 01 October 2013 17:05 Go to previous messageGo to next message
Hi I am having the same problem. I have gerrit 2.6 and eclipse juno 4.2. I updated the mylyn gerrit connector 2.1.0.
I am using openid authentication. when i click on validate button it is not forwarding to google login screen for login. Instead it is giving unable to login (screen shot attached). Any ideas why authentication is not working with openid
Re: Mylyn Reviews can't connect to https://git.eclipse.org/r [message #1123643 is a reply to message #1122692] Wed, 02 October 2013 15:48 Go to previous message
Eclipse.org doesn't support OpenID auth, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=243930 for justification.
Previous Topic:Gerrit versions
Next Topic:Failed to update model based on selection
Current Time: Sat Jul 26 12:58:13 EDT 2025
Powered by FUDForum. Page generated in 0.10856 seconds
