Home » Eclipse Projects » Commercial » Customized icons for commercial use
Customized icons for commercial use [message #1064828] Fri, 21 June 2013 05:27 Go to next message
Hey,
I'm developing a view and was looking for some matching icons. I found http://eclipse-icons.i24.cc showing http://eclipse-icons.i24.cc/ovr16/cheatsheet_obj.gif and http://eclipse-icons.i24.cc/ovr16/write_obj.gif.
I used both icons to create index.php/fa/15332/0/ and here the encoded as bas64:
Base64
R0lGODlhEAAQAIQaAD5yp7fS5BcyXaSDNI13Oa+JMX1xPayHMqmFM7KKMJZ8N35wPZJ6OaCBNZx/
Nfj9//z///b8//n9//T8//7+//r+//z+//3+/35xPfn+/////////////////////////yH5BAEK
AB8ALAAAAAAQABAAAAVv4Cd+AmmW5SgmARVAgRREQaJ+BXABFfAAE0DhdrgYj8fDDWFpOilNxG2Q
qVYpCUJmcGtYM9iAtnFzWMMMSsZxU1xZ6arixgAzAvEq46YFZNVWBDcYGQIAgFYYg1+MiiqEjIk3
HwYGCwsYmZmTnJMhADs=
and I also used the folder wizard icon http://eclipse-icons.i24.cc/ovr16/newprj_wiz.gif to create a nice wizard icon index.php/fa/15333/0/. Here the base64 string for it:
Base64
AB8ALAAAAAAQABAAAAV04Cd+AmmWyTgmARVAgRQkVKoWwAVUwJPQP9XhQiQmJEik7YOwOJ+HQySq
GmSu15oj4FB9GthMLUBwNLwO7JhByXRViiyLfVV4GWJGgH5leAkZAAkEbVgEXhgZAgCFWBiIYZGP
KomRjl4fBgYLCxienpihmCEAOw==
I used http://eclipse-icons.i24.cc/ovr16/prj_obj.gif and http://eclipse-icons.i24.cc/ovr16/task_complete.gif to create index.php/fa/15334/0/. Here the base64 encoding:
Base64
R0lGODlhEAAQAKU3AChGswBfPi5JsC9KsC9KsTVOrTlPrTlQrABuXT9UqkVVqEVWqEpapVFco1Jd
olZfnl9knWBknWBknl9lnWBlnWNnmXJxk4l7jZWBiJWBiYWRyH2/fNCseNCsedGteZK165K17JK2
65K27NmycZ3F8p7F8p3G8p7G8uPBfanV+KnW+KnW+ezRi//Rdf/VfbHh/f/aifbflv/flv/lpPrp
nv/rs//xwv///////////////////////////////////yH5BAEKAD8ALAAAAAAQABAAAAaJwJ9w
SCzeisjhbUP0OD3GDWLYuVlvHOtvidhkMhgaLcZCjbrcze2isbnftk1ArhZaavh8bTk/CiszgYKB
SzcVQw8yMhMREhGPEBQQEYw/DDCYDi+bnJwNPwkuLgsqKSsqK6mnCkIFLQYlJSYnJSckJycHQwIE
ICAhHyIfIb8DRQDIycpJzM3OQkEAOw==
I found newprj_wiz.gif in my eclipse folder and added the http://eclipse-icons.i24.cc/ovr16/task_complete.gif icon to create index.php/fa/15335/0/.
Base64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The base icon are published under the EPL license, so the newly created icons also use the EPL license.
Can I use this icons in my eclipse plug-in?
Thank you!
Kon
Re: Customized icons for commercial use [message #1065616 is a reply to message #1064828] Wed, 26 June 2013 12:59 Go to previous messageGo to next message
Hey,
I had to create some more icons using already present Eclipse icons (EPL). I used http://eclipse-icons.i24.cc/ovr16/prj_obj.gif to create index.php/fa/15373/0/ and index.php/fa/15374/0/.
And I used newprj_wiz.gif that I found in my eclipse folder to created index.php/fa/15375/0/ and index.php/fa/15376/0/.
Since the base icons were published under the EPL license, my newly created icon are also having the EPL license. Thank you.
Kon
Re: Customized icons for commercial use [message #1091556 is a reply to message #1065616] Wed, 21 August 2013 12:59 Go to previous messageGo to next message
Hey,
  • Used connect.gif to create index.php/fa/15971/0/.
  • Used monitor_view.gif and c_app.gif to create index.php/fa/15972/0/.
  • User classf_generate.gif to create index.php/fa/15974/0/.
  • Used newex_wiz.gif and sa_nav.png to create index.php/fa/15973/0/.
  • Used generate_ddl.gif and source_attach_attrib.gif to create index.php/fa/15975/0/.
Kon
Kon
[Updated on: Wed, 21 August 2013 13:00] by Moderator
Re: Customized icons for commercial use [message #1091976 is a reply to message #1091556] Thu, 22 August 2013 03:03 Go to previous messageGo to next message
Hey,
I made some more icons based on Eclipse icons (EPL).
  • Used root_main.gif to create index.php/fa/15978/0/, index.php/fa/15979/0/ and index.php/fa/15980/0/.
  • Used root_main.gif and c_app.gif to create index.php/fa/15981/0/.
  • Used new_chart.gif to create index.php/fa/15982/0/.
Since the base icons were published under the EPL license, my newly created icon are also distributed under the EPL license.
Thank you.
Kon
  • Attachment: group.png
    (Size: 0.25KB, Downloaded 1085 times)
  • Attachment: group_connected.png
    (Size: 0.27KB, Downloaded 1080 times)
  • Attachment: host.png
    (Size: 0.28KB, Downloaded 1134 times)
  • Attachment: master.png
    (Size: 0.26KB, Downloaded 1134 times)
  • Attachment: system_monitor.png
    (Size: 0.45KB, Downloaded 1125 times)
Re: Customized icons for commercial use [message #1091981 is a reply to message #1091976] Thu, 22 August 2013 03:10 Go to previous message
Hey,
I'm just able to attach five images on a singe post. For this reason I had to create multiple post. Here are some more icons that I created:
  • Used time_obj.gif to created index.php/fa/15983/0/.
  • Used track.gif, untrack.gif, clear_new.gif and my created profiler.png to create index.php/fa/15984/0/, index.php/fa/15985/0/ and index.php/fa/15986/0/.
Thank you!
Kon
Previous Topic:B-Folders 3: the Non-Cloud, Secure Organizer is Launched
Next Topic:JProbe
Current Time: Mon Jun 16 17:55:40 EDT 2025
Powered by FUDForum. Page generated in 0.08361 seconds
