Passing parameters while creating a view in Eclipse RCP [message #1064593] |
Thu, 20 June 2013 03:28 |
I am creating eclipse RCP application and I am stuck with passing parameter while showing a view. As the first approach, I tried setting a static variable in View2 from View1 and opened that view (as below). It works.
IWorkbenchPage activePage = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage();
String viewIdToClose = studentListView.ID;
IViewPart viewToClose = activePage.findView(viewIdToClose);
TableItem item = studentTable.getItem(studentTable.getSelectionIndex());
String text = item.getText(ListViewConstants.TABLE_COLUMN_ONE);
activePage.hideView(viewToClose);
try {
String viewIdToOpen = StudentReview.ID;
StudentReview.userId = text;
activePage.showView(viewIdToOpen);
} catch (PartInitException e) {...}
As this doesn't seem to be a good approach, I tried as per the suggestion mentioned in the below link(accepted answer). Passing parameters to the view . In this approach, we can pass parameters only after showing the view.
But the issue I have is, the view to be opened should have the value from selected row while calling showView() i.e, I want to populate the parameters in View 2 based on View 1's selection. Is there any way to achieve this? Is it good to use PULL instead of PUSH approach?
Any suggestion is appreciated.
Thanks!!!
FUDForum. Page generated in 0.24041 seconds
