Home » Eclipse Projects » Remote Application Platform (RAP) » Logout (RAP 2.1)
Logout (RAP 2.1) [message #1063641] Thu, 13 June 2013 10:56 Go to next message
I am migrating our RWT standalone application from RAP 1.4 to 2.1 (RC3).
Most of the changes worked without problems and our application is running with the new version.
The only unsolved problem is the logout procedure.
We used some old code examples to achieve the logout in RAP 1.4.
I tried to rework it with samples from the forum.
But I have not found a working solution.
Especially with the new multi-tab feature.
The tab that executes the logout (http session invalidation) will be logged out successfully and redirected to the login page.
The additional tabs are running into bug 390711 because we use form authentication in tomcat.
I tried to use the custom jsp from the bug. But if the ExitConfirmation is enabled and the user refuses the json redirect the client will crash with javascript error:
Error: TypeError: a is undefined
What is the preferred way to implement a logout procedure in RAP 2.1?
Oliver
Re: Logout (RAP 2.1) [message #1063763 is a reply to message #1063641] Fri, 14 June 2013 03:17 Go to previous messageGo to next message
Hi Oliver,
such kind of errors (JavaScript) are definitely bugs. Could you open a
bugzilla and provide more detailed information about the crash? A simple
project to reproduce the issue is welcomed.
Best,
Ivan
On 6/13/2013 5:56 PM, Oliver Mising name wrote:
> Hello,
> Oliver
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Logout (RAP 2.1) [message #1063768 is a reply to message #1063763] Fri, 14 June 2013 03:45 Go to previous messageGo to next message
Hi Ivan,
thanks for the reply.
Yes, I think it is a bug concerning the workaround login page in bug 390711.
The JSON-redirect is clashing with the exit confirmation breaking some code.
I will see if I can create a standalone example.
But is there any chance that bug 390711 will be fixed in the final 2.1?
Then the session timeout message will be displayed and the workaround would not be needed.
Oliver
Re: Logout (RAP 2.1) [message #1063811 is a reply to message #1063768] Fri, 14 June 2013 07:02 Go to previous messageGo to next message
Hi Oliver,
the problem with form-based authentication is that this method is just
not suitable for Ajax applications because it intercepts XHR reqests and
redirects to some login/logout HTML page. So the XHR request that
expects data in a given format will receive HTML content instead.
To make it worse, the redirect is completely transparent to the XHR API,
so there's no way for the client to react on it.
So there's no obvious fix for bug 390711. I didn't quite understand how
multiple tabs change the thing. Could you post the response JSON that
lead to the "TypeError: a is undefined"?
Ralf
Ralf Sternberg
Re: Logout (RAP 2.1) [message #1063824 is a reply to message #1063811] Fri, 14 June 2013 07:50 Go to previous messageGo to next message
Hi Ralf,
thanks for the explanation.
I understand now that there is no easy fix for bug 390711.
These were the steps that led to that error:
1. Open multiple tabs for the same application/session
2. In one tab the user presses logout and the http session is invalidated and the user is sent to logout/login page
3. The other tabs will be informed of the logout with the next request (tomcat redirects to login page because of the invalid session cookie)
4. That XHR request fails and the json redirect to the login page is issued (using the sample jsp login page from bug 390711)
5. Before the json redirect is processed the browser exit confirmation triggers
6. If the user denies the browser exit confirmation the javascript error occurs
Everything works fine if the user confirms the exit confirmation
This is the complete error message:
Client Error
Details:
  Script:
  "head": {
    "redirect": "https://localhost/App/start"
  fileName: https://localhost/App/rwt-resources/rap-client.js
  lineNumber: 228
  columnNumber: 130
  Stack: rwt.remote.MessageProcessor.processMessage@https://localhost/App/rwt-resources/rap-client.js:228
.members._handleSuccess@https://localhost/App/rwt-resources/rap-client.js:232
@https://localhost/App/rwt-resources/rap-client.js:96
rwt.remote.Request.prototype._onReadyStateChange@https://localhost/App/rwt-resources/rap-client.js:96
.statics.bind/d@https://localhost/App/rwt-resources/rap-client.js:14
  Debug: off
  Request: {"head":{"requestCounter":6},"operations":[["set","w23",{"activeControl":"w49"}],["set","w49",{"selection":["w108"]}],["notify","w49","Selection",{"item":"w108","detail":null,"shiftKey":false,"ctrlKey":false,"altKey":false}],["set","w49",{"focusItem":"w108"}],["notify","w49","MouseDown",{"button":1,"x":512,"y":401,"time":125465,"shiftKey":false,"ctrlKey":false,"altKey":false}],["notify","w49","MouseUp",{"button":1,"x":512,"y":401,"time":125577,"shiftKey":false,"ctrlKey":false,"altKey":false}],["set","w1",{"cursorLocation":[512,401],"focusControl":"w49"}]]}
Oliver
Re: Logout (RAP 2.1) [message #1063903 is a reply to message #1063824] Fri, 14 June 2013 17:30 Go to previous messageGo to next message
Thanks for your detailed explanation. Now I got it.
Obviously, the exit confirmation doesn't make sense when the session has
timed out, there is no way to continue anyway. We should probably
disable the exit confirmation just before following the redirect, as the
thing interferes with redirecting. Could you please open a new bug for this?
Unfortunately, it's too late to fix this for 2.1, but the fix could
become part of a service release.
Ralf
Ralf Sternberg
Re: Logout (RAP 2.1) [message #1063986 is a reply to message #1063903] Mon, 17 June 2013 03:05 Go to previous message
I opened the new bug for this topic:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=410895
Oliver
Previous Topic:TabFolders in RAP crash
Next Topic:RAP developers wanted
Current Time: Wed Jul 23 06:48:52 EDT 2025
Powered by FUDForum. Page generated in 0.06866 seconds
