Home » Eclipse Projects » Eclipse Platform » ftp target site error
ftp target site error [message #104739] Fri, 01 August 2003 09:38 Go to next message
Originally posted by: eweij.cgey.nl
I recieve a Code: -4 error when I try to add a ftp target site. The problem
is that I can connect to other ftp sites succesfully, but this one just
gives me a huge headache.
I turned debugging on as suggested in the FAQ and I can see that it stops
after sending the username.
Eclipse does connect cause it recieves a 220 status ready, but after sending
the username something seems to hang.
So maybe the ftp server is causing this. However I can connect to the remote
site with an ordinary ftp client with out any problems. Aaargggg
I'm using Eclipse version 2.1.1 and also the ftp pugins is version 2.1.1
OS = win2k pro
Sun SDK 1.4.2
FTP server wu-2.6.1-16.7x.1
Any help is appriciated
Re: ftp target site error [message #105195 is a reply to message #104739] Fri, 01 August 2003 17:24 Go to previous messageGo to next message
Originally posted by: birsan.nospam.ca.ibm.com
You may want to open a bug and provide the url that can be used for testing.
-dorian
"vdweij" <eweij@cgey.nl> wrote in message news:bgdqec$olp$1@eclipse.org...
problem
sending
remote
> OS = win2k pro
> Sun SDK 1.4.2
Re: ftp target site error [message #105837 is a reply to message #105195] Mon, 04 August 2003 01:57 Go to previous message
Unfortunately it is not possible to provide the url since the server can
only be accessed from the network at work.
I got a bit further however. Sometimes the debugging console also shows that
a password has been submitted. I even got through the entire authentication
process en received a dir list. But 99% if freezes after submitting the
username!
This probably makes it more complicated...
Kind regards,
Previous Topic:Changing default system fonts for Eclipse on Solaris?
Next Topic:change text file encoding
Current Time: Mon Nov 17 10:38:35 EST 2025
Powered by FUDForum. Page generated in 0.03761 seconds
