Home » Eclipse Projects » Eclipse 4 » Edit entities with context menu via parameterized commands
Edit entities with context menu via parameterized commands [message #1038186] Wed, 10 April 2013 10:19 Go to next message
Hello everybody,
I have the following use case: I have JFace tree with some nodes which represents my structured set of data. Now I want to edit these entities by right-clicking one node and selecting the "Edit" item from the context menu, which opens a separate dialog to edit the entity.
My idea to achieve this was using a parameterized command and an appropriate handler class like the following, but this didn't work for me. As you can see, I changed the String type of the parameter to any arbitrary Object, but I didn't figure out how to assign a parameter of the general object type to a command.
  @Execute
  public void execute(@Named("com.example.e4.rcp.todo.commandparameter.input") Object myObject) {
    System.out.println(param);
I currently haven't figured out how this works in a "beautiful way", so I constructed an ugly work-around: Every time the selection of my JFace tree changes, I use the event broker to post the selected entity. Any handler which subscribes to this post initializes itself with this entity. Now when the command is executed by clicking on a menu item, the corresponding (and already initialized) handler is executed.
	private Person person;
	@Inject
	private IEventBroker broker;
	@Inject
	@Optional
	public void initialize(@UIEventTopic("person_changed") Person person) {
		this.person = person;
	@CanExecute
	public boolean canExecute() {
		if (person!= null) {
			return true;
		return false;
	@Execute
	public void execute(Shell parent) {...}
Can anybody provide me a more beautiful way to achieve this functionality wihout using the event broker?
Thanks in advance
Regards, Andreas
Re: Edit entities with context menu via parameterized commands [message #1039447 is a reply to message #1038186] Fri, 12 April 2013 03:17 Go to previous messageGo to next message
Hi Andreas
you could use the ESelectionService to register the selection in your tree and then use the current selection in your handler.
Assuming you are using a JFace TreeViewer, the code to register the selection could look like this:
treeViewer.addSelectionChangedListener(new ISelectionChangedListener() {
	public void selectionChanged(SelectionChangedEvent event) {
		selectionService.setSelection(event.getSelection());
Your handler can then use this selection:
@CanExecute
public boolean canExecute(@Optional @Named(IServiceConstants.ACTIVE_SELECTION) Object selection) {
	if (selection == null) {
		return false;
	} else if (selection instanceof IStructuredSelection) {
		IStructuredSelection structured = (IStructuredSelection)selection;
		if (selection.isEmpty())
			return false;
		... test that selection has the right type ...
	} else {
		return false;
@Execute
public void execute(@Named(IServiceConstants.ACTIVE_SELECTION) IStructuredSelection selection) {
	... open the edit dialog ...
Greetings
Christoph
[Updated on: Fri, 12 April 2013 03:18] by Moderator
Re: Edit entities with context menu via parameterized commands [message #1039483 is a reply to message #1039447] Fri, 12 April 2013 04:08 Go to previous messageGo to next message
Why don't you propagate and then inject the specific domain object? DI is type sensitive so you would only get the method called if it is of the right type and would skip those 3.x style type checks.
Re: Edit entities with context menu via parameterized commands [message #1039484 is a reply to message #1039447] Fri, 12 April 2013 04:08 Go to previous messageGo to next message
Hi Christoph,
thanks for your help, this worked for me Smile
Regards, Andreas
Re: Edit entities with context menu via parameterized commands [message #1039492 is a reply to message #1039483] Fri, 12 April 2013 04:16 Go to previous messageGo to next message
Sopot Cela wrote on Fri, 12 April 2013 10:08
I find it more flexible to work with ISelection:
- handle multiple selection (could be of different types)
- use the adapter framework
Re: Edit entities with context menu via parameterized commands [message #1039499 is a reply to message #1039483] Fri, 12 April 2013 04:28 Go to previous message
Sorry ... now I get it. You probably mean:
@CanExecute
public boolean canExecute(@Optional @Named(IServiceConstants.ACTIVE_SELECTION) IStructuredSelection selection) {
		return false;
	} else if (selection.isEmpty()) {
		return false;
Previous Topic:EModelService can't find MMenuElement's
Next Topic:ActionHandler behavior change in Eclipse 4?
Current Time: Wed Jul 23 22:17:07 EDT 2025
Powered by FUDForum. Page generated in 0.03927 seconds
