Home » Archived » BIRT » Blank report in REMEDY 7.6(Report works in BIRT IDE, but not on Remedy mid tier - no data only column headings)
Blank report in REMEDY 7.6 [message #1036729] Mon, 08 April 2013 14:37 Go to next message
Hi All,
I'm using BIRT Designer 2.5. I have created a report in BIRT. I'm able to see the data in BIRT IDE, however, when I upload the design file in Remedy Mid Tier I do not see any data (only column headings).
I have tried every possible thing, any help on what could possibly be wrong, would be greatly appreciated. I have upload the RPT design file for reference.
Thank in advance
-vik
[Updated on: Mon, 08 April 2013 23:44] by Moderator
Re: Blank report in REMEDY 7.6 [message #1037021 is a reply to message #1036729] Tue, 09 April 2013 00:58 Go to previous messageGo to next message
I've not used Remedy, but there is a PDF hidden behind a login (which I don't have) on the BMC Software website that tells how to create/modify reports and use them with Remedy:
http://documents.bmc.com/supportu/documents/16/62/271662/271662.pdf
Here is the post it comes from:
https://communities.bmc.com/communities/thread/51268
Re: Blank report in REMEDY 7.6 [message #1037186 is a reply to message #1037021] Tue, 09 April 2013 05:04 Go to previous messageGo to next message
Hi Michael,
Thanks for your time. I have this document with me. It's a basic kick-start document to start developing web report for Remedy, not of much use. I have faced this issue randomly in some other reports too. Talking about this one, It worked fine for some time before it stopped displaying the data at a later stage.
I was able to see the output after redesigning the report from scratch in other cases. But for this one, nothing seems to be a working solution. I hope it helps in understanding the issue better. Any insight ?
-vik
[Updated on: Tue, 09 April 2013 05:05] by Moderator
Re: Blank report in REMEDY 7.6 [message #1037594 is a reply to message #1037186] Tue, 09 April 2013 15:18 Go to previous messageGo to next message
If the column headers are showing correctly and it's just not bringing in data, it sounds like a parameterized report that's sending a bad value or something, so no values come back. I'll take a look at the actual report and let you know if I see anything that might cause a hang-up. With your saying that it worked before and just stopped working though, that makes it seem less likely that there's a problem with the actual design.
Re: Blank report in REMEDY 7.6 [message #1037600 is a reply to message #1037594] Tue, 09 April 2013 15:29 Go to previous message
The above presumed you didn't get any errors about connecting to your data. There are lots of joins. You might make sure that there are no issues with fields matching up correctly. If you run the report from the designer, does everything work as expected? Do you have other reports that use this same data that are working fine?
Previous Topic:Table Footer at end of Every Page
Next Topic:Birt nested Table with ECore ODA Problem
Current Time: Tue Oct 28 23:36:00 EDT 2025
Powered by FUDForum. Page generated in 0.24979 seconds
