Home » Newcomers » Newcomers » How to create a standalone app?
How to create a standalone app? [message #102881] Mon, 19 September 2005 07:31 Go to next message
Originally posted by: leo_zen.gmx.at
I have written my first app in Eclipse and now have the problem, not
knowing how to export it as standalone java-app.
What I've done:
Export => select the path 'src' with everything in it, selected 'export
generated class files and resources', specified a destination, selected to
generate a new Manifest and specify the main-entry point. Click on
'Finish' and I receive 'JAR creation failed with a list of 'Warnings'.
When I try to launch the app with
java -jar test.jar
I get an exception,
Exception in thread "main" java.lang.NoClassDefFoundError:
org/apache/log4j/Logger
And here I don't know, where to define the missing files. Startup via
Eclipse works without any kind of problem.
Anybody an idea what's missing?
Re: How to create a standalone app? [message #102911 is a reply to message #102881] Mon, 19 September 2005 08:34 Go to previous messageGo to next message
> What I've done:
> to generate a new Manifest and specify the main-entry point. Click on
> java -jar test.jar
> I get an exception,
The jars your application depends on are probably missing from the
classpath.
Here is some information on the classpath and various ways to set it for
your application.
http://java.sun.com/j2se/1.5.0/docs/tooldocs/windows/classpa th.html
There are some good tutorials if you are new to java on java.sun.com.
Peter
Re: How to create a standalone app? [message #102924 is a reply to message #102911] Mon, 19 September 2005 09:22 Go to previous messageGo to next message
> classpath.
I highly assumend that the export of Eclipse does this. i.e. include the
Classpath into the Manifest, resp. provide a fully functional export to
one dir.
so, I have in my project 'external' jars, which are included in my project
build path. execution via Eclipse works fine. but for the standalone, I
have to take care by myself?
additionally not very clear for me, how to set them. should I include them
as well into my jar-file, or keep them separte?
Re: How to create a standalone app? [message #102950 is a reply to message #102924] Mon, 19 September 2005 09:29 Go to previous messageGo to next message
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
In article <df9a51c91e973cb630f6d77048f51f49$1@www.eclipse.org>,
leo_zen@gmx.at says...
> > classpath.
> one dir.
You can't put jars within jars, so you need to have them either in the
same folder, or on the classpath.
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: How to create a standalone app? [message #102970 is a reply to message #102950] Mon, 19 September 2005 09:48 Go to previous messageGo to next message
OK, so in the same folder! So, I've put everything of the required
external jars into the same folder as the created jar from my source code.
start again with
java -jar test.jar
=> same error
Re: How to create a standalone app? [message #103039 is a reply to message #102970] Mon, 19 September 2005 12:28 Go to previous message
I found a solution to add it into the Manifest and keep it in the same dir.
Previous Topic:How to get the system env variables in eclipse?
Next Topic:pathes for a standalone-app
Current Time: Sun Jul 27 03:31:25 EDT 2025
Powered by FUDForum. Page generated in 0.11378 seconds
