Home » Eclipse Projects » GEF » OrphanChildCommand
OrphanChildCommand [message #102782] Wed, 29 October 2003 21:00 Go to next message
Originally posted by: snowice.asiamail.com
I would like to know what's is the rold of the OrphanChildCommand in the
Logic example, in terms of implementation, it looks highly similar to the
DeleteCommand. When is it actually invoked?
Thanks.
regards,
Evon
Re: OrphanChildCommand [message #102795 is a reply to message #102782] Wed, 29 October 2003 21:21 Go to previous messageGo to next message
Originally posted by: qiuyunzhong.hotmail.com
It's invoked by LogicContainerEditPolicy when you remove a child from the
container.When you delete some components, deletecommand will be called
instead.
"Evon" <snowice@asiamail.com> ??????:bnprc3$qrf$1@eclipse.org...
> Thanks.
> regards,
> Evon
Re: OrphanChildCommand [message #102804 is a reply to message #102782] Wed, 29 October 2003 22:57 Go to previous messageGo to next message
The difference in orphan and delete is that connection can be left alone
when orphaning, since you know the object will still exist somewhere else.
"Evon" <snowice@asiamail.com> wrote in message
news:bnprc3$qrf$1@eclipse.org...
> Thanks.
> regards,
> Evon
Re: OrphanChildCommand [message #102821 is a reply to message #102804] Thu, 30 October 2003 00:04 Go to previous messageGo to next message
the object will still exist? where will it exist? and what's the point of
seemingly deleting it and letting it exist somewhere?
regards,
Evon
Re: OrphanChildCommand [message #102833 is a reply to message #102821] Thu, 30 October 2003 00:30 Go to previous messageGo to next message
In my opinion,when you call orphanchildcommand, you remove child from the
container to some where else, for example,another container.But the child is
still exist in some palace you lay it ,if it has connection to the container
then the connection is still remained.When you delete a child connected to
others, the connection will be deleted with the child.
"Evon" <snowice@asiamail.com> ??????:bnq654$4du$1@eclipse.org...
else.
> regards,
> Evon
Re: OrphanChildCommand [message #102843 is a reply to message #102833] Thu, 30 October 2003 01:33 Go to previous messageGo to next message
I got it! Thanks.
> else.
> > regards,
> > Evon
Re: OrphanChildCommand [message #102892 is a reply to message #102782] Thu, 30 October 2003 11:34 Go to previous message
Originally posted by: Lamont_Gilbert.Rigidsoftware.com
On Thu, 30 Oct 2003 02:00:35 +0000, Evon wrote:
> the
> the DeleteCommand. When is it actually invoked?
> Thanks.
> regards,
> Evon
Orphan occurs for instance when you have 2 container Edit Parts in the
display. And you drag a child from within its container, over into
another container. That will be an orphan-add operation.
I don't see how
connections can possibly survive an EditPart changing containers though...
I found no proactical use for orphan and so far I am not using it. Perhaps
as I near completion I will find a usage.
Previous Topic:Focus-related exception
Next Topic:[ANN] Requirements for rulers in graphical editors
Current Time: Thu Sep 18 19:01:05 EDT 2025
Powered by FUDForum. Page generated in 0.04188 seconds
