Home » Archived » Jubula » Is there way to access Table Header in Jubula
Is there way to access Table Header in Jubula [message #1022129] Thu, 21 March 2013 06:19 Go to next message
I have application which displays result set in Table view. Some of the columns are not displayed by default. If data needs to be sorted than it can be done on Columns headings.
I am trying to sort on single column and multiple columns by right click on column header and set the required criteria.
Is it possible to do so?
[Updated on: Thu, 21 March 2013 06:21] by Moderator
Re: Is there way to access Table Header in Jubula [message #1022616 is a reply to message #1022129] Fri, 22 March 2013 04:49 Go to previous message
Yes, that is possible. You can select the header row using the row index "0" (e.g. with 0 clicks, just to position the mouse) and then use the actions for selecting from context menus.
HTH,
Alex
Previous Topic:Can I email the Test Summary result to my Email account?
Next Topic:EclipseCon time and Easter time
Current Time: Wed Jul 23 06:14:51 EDT 2025
Powered by FUDForum. Page generated in 0.28954 seconds
