Home » Eclipse Projects » Remote Application Platform (RAP) » Misaligned Table Column Headers
Misaligned Table Column Headers [message #1015880] Mon, 04 March 2013 01:53 Go to next message
Hey!
Still fighting/playing (choose Wink) with tables. I'm currently bringing our "setting" support (written for SWT table) to RAP. now in some cases this thing tries to hide columns by setting the width to zero. In some cases this works, and in some i get weirdly misaligned headers (see screenshots). Also it seems that /sometimes/ not even a zero width is required but table headers are expanded to fit the text in them (but really not always - you can see that in the first screeny).
Hm, having more looks it seems that /that's/ the only issue: the contents makes the headers expand. i just have so many of them (see first screeny) that multiple of them overlap and make it look quite weird.
index.php/fa/13650/0/
index.php/fa/13651/0/
From the second one you can see that the last column (Fixed) should not be visible at all (no borders drawn in table) but the header is there, and (by accident?) has the exact size of the contents. i think there is a little bit missing...?
Another detail: i cannot reproduce this by dragging headers to different sizes - this works well. it seems that it's "only" reproducable through setWidht(), and there not always.
EDIT: in the second screeny, the label for the first column should have been "Name", also. The "Identifier" is another one of those "hidden" columns (width=0).
Any Ideas? maybe some workaround? even in JS, i take all Wink)
Markus
[Updated on: Mon, 04 March 2013 01:55] by Moderator
Re: Misaligned Table Column Headers [message #1015884 is a reply to message #1015880] Mon, 04 March 2013 02:26 Go to previous messageGo to next message
Hi Markus,
without a way to reproduce and debug it we can't help you much. Please
open a bugzilla about this issue. Are you using RAP 2.0? Is this happen
in all browsers - Firefox, IE, Chrome?
Best,
Ivan
On 3/4/2013 8:53 AM, Markus Duft wrote:
> Hey!
> Still fighting/playing (choose ;)) with tables. I'm currently bringing our "setting" support (written for SWT table) to RAP. now in some cases this thing tries to hide columns by setting the width to zero. In some cases this works, and in some i get weirdly misaligned headers (see screenshots). Also it seems that /sometimes/ not even a zero width is required but table headers are expanded to fit the text in them (but really not always - you can see that in the first screeny).
> Any Ideas? maybe some workaround? even in JS, i take all ;))
> Markus
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Misaligned Table Column Headers [message #1015888 is a reply to message #1015884] Mon, 04 March 2013 03:02 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=402270
there is a small sample code also
Re: Misaligned Table Column Headers [message #1015890 is a reply to message #1015888] Mon, 04 March 2013 03:09 Go to previous messageGo to next message
Ivan Furnadjiev
Re: Misaligned Table Column Headers [message #1016451 is a reply to message #1015890] Wed, 06 March 2013 08:47 Go to previous message
i have added a workaround proposal to the bug. and i have a question about it:
i try to patch (using rwt.qx.Class.patch) the GridHeader class. when i do it before the GridHeader constructor ran for the first time, the prototype is empty (thus the new() in my patch). in that case the mixin will be applied to an empty prototype, and it will result in a reverse order of functions (the mixin is base() of the actual implementation in RWT). is this desired/known behaviour? i mean it works the way i have it, but "clean" is something else Very Happy
Previous Topic:Checking Browser type & Version Number
Next Topic:RWT ServiceManager
Current Time: Sun Jul 20 21:22:58 EDT 2025
Powered by FUDForum. Page generated in 0.05550 seconds
