Home » Archived » BIRT » Is it possible to insert/remove table columns dynamically in BIRT?
Is it possible to insert/remove table columns dynamically in BIRT? [message #99026] Wed, 14 December 2005 10:11 Go to next message
I’m trying ( BIRT 1.0.1) to insert columns to a table dynamically, but I
can not find the right method in the API’s.
If yes how to do that?
Said
Re: Is it possible to insert/remove table columns dynamically in BIRT? [message #101201 is a reply to message #99026] Wed, 21 December 2005 12:16 Go to previous messageGo to next message
I believe you would have to use the Report Engine API which has a handle to
the report desgin.
You would take the handle load the Report using the DE API modify the table
and then reload it in the Engine. This could be done all in memory using
the engine.openReportDesign( InputStream) method.
Jason Weathersby
BIRT PMC
"S.Taaouati" <said.taaouati@remain.nl> wrote in message
news:1bb5cbf0fd08c664de913a24af61129b$1@www.eclipse.org...
> I
Re: Is it possible to insert/remove table columns dynamically in BIRT? [message #101530 is a reply to message #101201] Thu, 22 December 2005 04:33 Go to previous messageGo to next message
In order to modify the table I’m using this:
// add a new column to “table”
ColumnHandle colH = table.getElementFactory().newTableColumn();
TableHandle item = table.getElementFactory().newTableItem("tableItem", 3);
Further there is no method in TableHandle object that can add a new
column.
Can you give an example how to do this please?
Re: Is it possible to insert/remove table columns dynamically in BIRT? [message #101809 is a reply to message #101530] Thu, 22 December 2005 15:34 Go to previous messageGo to next message
Try doing this
TableHandle th = factory.newTableItem("test",2);
SlotHandle slot = th.getColumns();
ColumnHandle ch = factory.newTableColumn();
slot.add(ch);
design.getBody().add( th);
HTH
Jason Weathersby
BIRT PMC
news:972f2f458f3aece3471c36575d4087f9$1@www.eclipse.org...
Re: Is it possible to insert/remove table columns dynamically in BIRT? [message #102006 is a reply to message #101809] Fri, 23 December 2005 03:41 Go to previous messageGo to next message
The following code creates a new table with two columns instead of add a
column to the existing table.
slot.add(ch);
What I try to do is this:
table1:
| col1 | col2 |
add col3 to tabl1:
| col1 | col2 | col3 |
remove col3 from table1:
| col1 | col2 |
Said
Re: Is it possible to insert/remove table columns dynamically in BIRT? [message #102133 is a reply to message #102006] Fri, 23 December 2005 13:57 Go to previous messageGo to next message
Adding and Deleting Columns requires worrying about groups and the number of
rows.
I was able to get this to work using the TableHandleAdapter class, which is
used by the GUI.
Might not be the right thing to do, but here is a snippet.
//name of my table
TableHandle th = (TableHandle)design.findElement("test");
TableHandlerAdapter hta = new TableHandleAdapter( th, null);
tha.insertColumn(1, 1);
or
tha.deleteColumn(1);
HTH
Jason
news:3fa59c9e582034a17dbea382c23cbfd3$1@www.eclipse.org...
> slot.add(ch);
> table1: ----------------------------
> | col1 | col2 | | | |
> add col3 to tabl1:
> | col1 | col2 | | | |
> Said
Re: Is it possible to insert/remove table columns dynamically in BIRT? [message #102472 is a reply to message #102133] Tue, 27 December 2005 03:19 Go to previous messageGo to next message
The class TableHandleAdapter consists of insert/delete column, but it is
not included in the API’s.
How can I use it in mine application?
Said
Re: Is it possible to insert/remove table columns dynamically in BIRT? [message #103703 is a reply to message #102472] Tue, 03 January 2006 14:22 Go to previous message
Said,
If you download the source you can look at the TableHandleAdapter class.
I used it by importing it
import
org.eclipse.birt.report.designer.core.model.schematic.TableH andleAdapter
It is in core.jar.
Jason
news:b2c8ae1be6e459b707d53c72873556a8$1@www.eclipse.org...
Previous Topic:I have some problem in showng image in html correctly
Next Topic:Problem with number alignment
Current Time: Sat Nov 08 05:55:46 EST 2025
Powered by FUDForum. Page generated in 0.09512 seconds
