Home » Language IDEs » Java Development Tools (JDT) » Eclipse freezes after opening wsdl in design( gui ) mode on Arch Linux + Openbox
Eclipse freezes after opening wsdl in design( gui ) mode on Arch Linux + Openbox [message #1000448] Mon, 14 January 2013 14:53 Go to next message
Hi ,
eclipse freezes when I switch wsdl file from design (graphical) view to source view or vice versa. Installation Arch Linux x86_64 + Openbox. The problem is on Eclipse Juno as well as previous versions of Eclipse on Arch Linux + OpenBox. I did not face this problem on CruchBang which also uses OpenBox. But I have seen this problem on Arch Linux + OpenBox. This problem also exists on ArchBang which uses Arch Linux + OpenBox.
Re: Eclipse freezes after opening wsdl in design( gui ) mode on Arch Linux + Openbox [message #1000545 is a reply to message #1000448] Mon, 14 January 2013 19:52 Go to previous messageGo to next message
"freeze" as in stops entirely no matter how long you wait, or as in "doesn't respond for some time before coming back"?
You may be interested to know that for Juno SR2 some fixes of significant performance bugs are in the pipe-line.
Using a recent maintenance build [1] should give you an idea of what it will be for SR2.
BTW, where's the connection to JDT in your question?
best,
Stephan
[1] http://download.eclipse.org/eclipse/downloads/drops4/M20130109-1200/
Re: Eclipse freezes after opening wsdl in design( gui ) mode on Arch Linux + Openbox [message #1000632 is a reply to message #1000545] Tue, 15 January 2013 01:05 Go to previous messageGo to next message
Stephan Herrmann wrote on Mon, 14 January 2013 19:52
Stops entirely no matter how long you wait. This happens only on ArchLinux + OpenBox or ArchBang linux. I posted on ArchBang forum some time back. I also tried AUR eclipse package. But it has same problem. I posted it on AUR as well. I am not able to post links because I have less than 5 messages and forum doesn't allow me to post links.
Because I am new here. This was my first post.
Re: Eclipse freezes after opening wsdl in design( gui ) mode on Arch Linux + Openbox [message #1000808 is a reply to message #1000632] Tue, 15 January 2013 08:04 Go to previous messageGo to next message
Please have a look at http://wiki.eclipse.org/How_to_report_a_deadlock
If you can produce any interesting information consider filing a bug.
Please note that the WSDL editor is provided by the Web Tools Project (see http://www.eclipse.org/forums/index.php/f/88/ )
cheers,
Stephan
Re: Eclipse freezes after opening wsdl in design( gui ) mode on Arch Linux + Openbox [message #1000834 is a reply to message #1000808] Tue, 15 January 2013 08:53 Go to previous message
This is helpful. Thanks for help.
Previous Topic:Rename - Refactor hotkey inserts registered trademark symbol
Next Topic:Stable JDT anywhere
Current Time: Sat Jul 26 10:44:47 EDT 2025
Powered by FUDForum. Page generated in 0.04834 seconds
