| Unhandled event loop exception --> java.lang.NullPointerException [message #305085] |
Thu, 22 June 2006 10:26 |
Originally posted by: kja.eswar.gmail.com
Hi all,
I'm just trying to run through the GEF shapes example, and I'm blocked on a strange behavior. I just imported the src into a new plug in project which I have created. I am just trying to run it and I get the following error.
Reason:
In the .log file, I find the exception shown at the end of this messasge. I'm running Eclipse 3.1 . Can someone give me a hint? I'm totally lost!
Thanks in advance,
Eswar
PLUGIN.XML
<?eclipse version="3.0"?>
<plugin>
<extension point="org.eclipse.ui.editors">
<editor name="GEF Shapes Example"
extensions="shapes"
icon="shapes.gif"
default="true"
class="org.eclipse.gef.examples.shapes.ShapesEditor"
contributorClass=" org.eclipse.gef.examples.shapes.ShapesEditorActionBarContrib utor "
id="GEF Shapes Editor">
</editor>
</extension>
<extension point="org.eclipse.ui.newWizards">
<category name="Examples"
parentCategory="org.eclipse.ui.Examples"
id="org.eclipse.gef.examples"/>
<wizard name="Shapes Diagram"
icon="shapes.gif"
category="org.eclipse.ui.Examples/org.eclipse.gef.examples"
class="org.eclipse.gef.examples.shapes.ShapesCreationWizard "
id="org.eclipse.gef.examples.shapes.ShapesCreationWizard">
<selection class="org.eclipse.core.resources.IResource"/>
</wizard>
</extension>
</plugin>
LOG ENTRY
!SESSION 2006-06-22 19:42:03.562 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.4.2_06
Framework arguments: -product org.eclipse.sdk.ide -pdelaunch
Command-line arguments: -product org.eclipse.sdk.ide -data D:\eclipse\TestProjects\runtime-EclipseApplication -dev file:D:/eclipse/TestProjects/TestEditor/.metadata/.plugins/o rg.eclipse.pde.core/Eclipse Application/dev.properties -pdelaunch -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2006-06-22 19:42:33.218
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-06-22 19:42:33.375
!MESSAGE java.lang.NullPointerException
!STACK 0
at org.eclipse.ui.internal.ide.dialogs.CreateLinkedResourceGrou p.createStatus(CreateLinkedResourceGroup.java:232)
at org.eclipse.ui.internal.ide.dialogs.CreateLinkedResourceGrou p.validateLinkLocation(CreateLinkedResourceGroup.java:411)
at org.eclipse.ui.dialogs.WizardNewFileCreationPage.validateLin kedResource(WizardNewFileCreationPage.java:530)
at org.eclipse.ui.dialogs.WizardNewFileCreationPage.validatePag e(WizardNewFileCreationPage.java:567)
at org.eclipse.gef.examples.shapes.ShapesCreationWizard$Creatio nPage.validatePage(ShapesCreationWizard.java:155)
at org.eclipse.ui.dialogs.WizardNewFileCreationPage.handleEvent (WizardNewFileCreationPage.java:460)
at org.eclipse.ui.internal.ide.misc.ResourceAndContainerGroup.h andleEvent(ResourceAndContainerGroup.java:250)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:848)
at org.eclipse.swt.widgets.Text.wmCommandChild(Text.java:2061)
at org.eclipse.swt.widgets.Control.WM_COMMAND(Control.java:3164 )
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3041 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:158 0)
at org.eclipse.swt.widgets.Text.callWindowProc(Text.java:131)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3123 )
at org.eclipse.swt.widgets.Text.windowProc(Text.java:1777)
at org.eclipse.swt.internal.win32.OS.SetWindowTextW(Native Method)
at org.eclipse.swt.internal.win32.OS.SetWindowText(OS.java:2355 )
at org.eclipse.swt.widgets.Text.setText(Text.java:1593)
at org.eclipse.ui.internal.ide.misc.ResourceAndContainerGroup.s etResource(ResourceAndContainerGroup.java:293)
at org.eclipse.ui.dialogs.WizardNewFileCreationPage.setFileName (WizardNewFileCreationPage.java:516)
at org.eclipse.gef.examples.shapes.ShapesCreationWizard$Creatio nPage.createControl(ShapesCreationWizard.java:91)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.ja va:179)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:611)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog .java:965)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1016)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1013)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.jav a:1003)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1001)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:753)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ui.actions.NewExampleAction.run(NewExampleAction .java:120)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
FUDForum. Page generated in 0.02642 seconds
