Home » Eclipse Projects » Buckminster dev » P2 work on Buckminster
P2 work on Buckminster [message #30558] Wed, 28 January 2009 19:03 Go to next message
The work of integrating P2 into Buckminster has commenced. First out was
the 'eclipse.import' reader type since it was rendered useless for new
update sites that lack the site.xml (the new Galileo sites are examples
of this).
I uploaded new versions containing the upgraded 'eclipse.import' reader
type today. Both for the Ganymede (i.e. Eclipse 3.4) and Galileo
(Eclipse 3.5) platforms. URL's for update sites and the latest products
can as usual be found here:
http://www.eclipse.org/buckminster/downloads.html
Thomas Hallgren
Re: P2 work on Buckminster [message #30593 is a reply to message #30558] Thu, 29 January 2009 04:40 Go to previous messageGo to next message
Originally posted by: news.eclipse.org.08.lemmster.de
Thomas Hallgren wrote:
> of this).
Hi Thomas,
thanks for implementing this new feature. :-) However, I'm unable to
materialize ECF's dependencies with
http://download.eclipse.org/eclipse/updates/3.5-I-builds/. BM complains
about org.eclipse.platform being unavailable on the site. But the
repository works for e.g org.eclipse.core.runtime.
Has BM's metadata changed or is this a bug?
ERROR : No suitable provider for component
org.eclipse.platform:eclipse.feature was found in searchPath org.eclipse
ERROR : Rejecting provider
eclipse.import(http://download.eclipse.org/eclipse/updates/3.5-I-builds/):
No component match was found
ERROR : Provider
cvs(:pserver:anonymous@dev.eclipse.org:/cvsroot/eclipse,org.eclipse.releng/maps):
Score is below threshold
org.eclipse.core.runtime:osgi.bundle/[3.4.0,4.0.0)#OSGi:
Using resource map file:/opt/hudson/jobs/N-HEAD-ECF/workspace/ecf.rmap
Using search path org.eclipse
Trying provider
Found match 3.5.0.v20090119
Using provider
org.eclipse.update.ui:osgi.bundle: Using resource map
org.eclipse.update.ui:osgi.bundle: Using search path
org.eclipse
org.eclipse.update.ui:osgi.bundle: Trying provider
org.eclipse.update.ui:osgi.bundle: Found match
3.2.200.v20081215
org.eclipse.update.ui:osgi.bundle: Using provider
org.eclipse.ui:osgi.bundle/[3.4.0,4.0.0)#OSGi: Using
org.eclipse.ui:osgi.bundle/[3.4.0,4.0.0)#OSGi: Using search
path org.eclipse
org.eclipse.ui:osgi.bundle/[3.4.0,4.0.0)#OSGi: Trying
provider
org.eclipse.ui:osgi.bundle/[3.4.0,4.0.0)#OSGi: Found match
3.5.0.I20090128-0800
[java] org.eclipse.ui:osgi.bundle/[3.4.0,4.0.0)#OSGi: Using
provider
Markus
Re: P2 work on Buckminster [message #30628 is a reply to message #30593] Thu, 29 January 2009 05:21 Go to previous messageGo to next message
Hi Markus,
Markus Alexander Kuppe wrote:
> ... BM complains about org.eclipse.platform being unavailable on the site.
> But the repository works for e.g org.eclipse.core.runtime.
I guess that depends on how you look at it. The metadata has indeed
changed. The platform feature for instance, is represented by an IU
named 'org.eclipse.platform.feature.group'. It in turn, has a
requirement for another IU called 'org.eclipse.platform.feature.jar'
which is what you normally would import.
I can of course change Buckminster to recognize this so that if you
search for a feature, it could check if the name ends with
'feature.group' and if not, append it, and then traverse the
relationship to the jar file.
If I fix this, and check it in, will you be able to test it from trunk?
Thomas Hallgren
Re: P2 work on Buckminster [message #30663 is a reply to message #30628] Thu, 29 January 2009 05:46 Go to previous messageGo to next message
+1 Otherwise I'd have to change all references from
"org.eclipse.platform" to "org.eclipse.platform.feature.group" just when
I change from old update manager to p2. IMO this is an implementation
detail of p2 and thus should be hidden from the consumer.
Sure, no problem.
Markus
Re: P2 work on Buckminster [message #30698 is a reply to message #30663] Thu, 29 January 2009 06:06 Go to previous messageGo to next message
> Sure, no problem.
I'm able to materialize the org.eclipse.platform feature now. Please
test the last check-in (rev 9898) of the org.eclipse.buckminster.pde
project.
- thomas
Re: P2 work on Buckminster [message #30734 is a reply to message #30698] Thu, 29 January 2009 06:57 Go to previous messageGo to next message
>> Sure, no problem.
> project.
Looks good, thanks for the help. :-)
Markus
Re: P2 work on Buckminster [message #30769 is a reply to message #30698] Thu, 29 January 2009 07:18 Go to previous messageGo to next message
>> Sure, no problem.
> project.
Resolution seems to work fine now, however the moment materialization
starts BM fails with:
[java] Provider
cvs(:pserver:anonymous@dev.eclipse.org :/cvsroot/rt,org.eclipse.ecf/framework/bundles/org.eclipse.e cf.identity):
materializing to
/opt/hudson/jobs/N-HEAD-ECF/workspace/plugins/org.eclipse.ec f.identity/
[java] ERROR [0003] : Error parsing site stream. [White spaces
are required between publicId and systemId.]
[java] org.xml.sax.SAXParseException: White spaces are required
[java] at
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. createSAXParseException(ErrorHandlerWrapper.java:236)
[java] at
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. fatalError(ErrorHandlerWrapper.java:215)
[java] at
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(XMLErrorReporter.java:386)
[java] at
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(XMLErrorReporter.java:316)
[java] at
com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFat alError(XMLScanner.java:1438)
[java] at
com.sun.org.apache.xerces.internal.impl.XMLScanner.scanExter nalID(XMLScanner.java:1024)
[java] at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.scanDoctypeDecl(XMLDocumentScannerImpl.java:595)
[java] at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$PrologDispatcher.dispatch(XMLDocumentScannerImpl.java:860 )
[java] at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 368)
[java] at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:834)
[java] at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:764)
[java] at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:148)
[java] at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1242)
[java] at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
[java] at
org.eclipse.update.core.model.DefaultSiteParser.parse(Defaul tSiteParser.java:152)
[java] at
org.eclipse.update.core.model.SiteModelFactory.parseSite(Sit eModelFactory.java:81)
[java] at
org.eclipse.update.internal.core.SiteURLFactory.createSite(S iteURLFactory.java:80)
[java] at
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:334)
[java] at
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:326)
[java] at
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:298)
[java] at
org.eclipse.update.internal.core.InternalSiteManager.attempt CreateSite(InternalSiteManager.java:222)
[java] at
org.eclipse.update.internal.core.InternalSiteManager.getSite (InternalSiteManager.java:162)
[java] at
org.eclipse.update.core.SiteManager.getSite(SiteManager.java :80)
[java] at
org.eclipse.buckminster.core.reader.SiteFeatureReaderType.ge tSite(SiteFeatureReaderType.java:66)
[java] at
org.eclipse.buckminster.core.reader.SiteFeatureReaderType.ge tSiteFeature(SiteFeatureReaderType.java:87)
[java] at
org.eclipse.buckminster.core.reader.SiteFeatureReader.getFea ture(SiteFeatureReader.java:39)
[java] at
org.eclipse.buckminster.core.internal.ctype.SiteFeatureResol utionBuilder.build(SiteFeatureResolutionBuilder.java:92)
[java] at
org.eclipse.buckminster.core.ctype.AbstractComponentType.get Resolution(AbstractComponentType.java:219)
[java] at
org.eclipse.buckminster.core.ctype.AbstractComponentType.get Resolution(AbstractComponentType.java:229)
[java] at
org.eclipse.buckminster.pde.internal.EclipsePlatformReaderTy pe.convertToSiteFeatures(EclipsePlatformReaderType.java:248)
[java] at
org.eclipse.buckminster.core.materializer.AbstractSiteMateri alizer.collectSites(AbstractSiteMaterializer.java:161)
[java] at
org.eclipse.buckminster.core.materializer.AbstractSiteMateri alizer.materialize(AbstractSiteMaterializer.java:320)
[java] at
org.eclipse.buckminster.core.materializer.MaterializerJob.ru n(MaterializerJob.java:71)
[java] at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
[java] ERROR: Unable to obtain site from:
[java] org.eclipse.core.runtime.CoreException: Unable to access
"http://download.eclipse.org/eclipse/updates/3.5-I-builds".
[java] at
org.eclipse.update.core.Utilities.newCoreException(Utilities .java:223)
[java] at
org.eclipse.update.core.Utilities.newCoreException(Utilities .java:254)
[java] at
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:318)
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
Markus
Re: P2 work on Buckminster [message #30804 is a reply to message #30769] Thu, 29 January 2009 07:26 Go to previous messageGo to next message
>>> Sure, no problem.
>> project.
FWIW here's the BOM that comes out of resolution
http://ecf2.osuosl.org/org.eclipse.ecf.sdk.mspec.bom
Re: P2 work on Buckminster [message #30838 is a reply to message #30769] Thu, 29 January 2009 07:26 Go to previous messageGo to next message
Hi Marcus,
The target platform materializer is not yet P2'ized. It is the next part
of the integration effort.
Meanwhile, do you think you could switch to using the workspace
materializer for these components? Importing binary bundles to the
workspace should work just fine.
Thomas Hallgren
>>> Sure, no problem.
>> project.
> [java] Provider
> materializing to
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> Markus
Re: P2 work on Buckminster [message #30873 is a reply to message #30838] Thu, 29 January 2009 07:34 Go to previous messageGo to next message
> Hi Marcus,
It works fine during import, but not so well during export [1]. So the
answer is no. We cannot use the workspace materializer.
Do you have some pointers where one can help p2-ized the platform
materializer?
Markus
[1] https://bugs.eclipse.org/240821
Re: P2 work on Buckminster [message #30908 is a reply to message #30873] Thu, 29 January 2009 07:46 Go to previous messageGo to next message
the > answer is no. We cannot use the workspace materializer.
Who needs PDE export ;-) ?
Seriously, Buckminster should be OK to use for these exports. It doesn't
have the same limitations as the PDE has with this.
> materializer?
In essence, the platform materializer should install bundles into the
SDK profile using the P2 director instead of using the old Update
Manager. I think that actually simplifies things a lot since all code
that wraps free-standing plug-ins in generated features can be removed.
The best pointer is probably to start here:
http://wiki.eclipse.org/Equinox_p2_Getting_Started_for_Devel opers
and have a look at the director application. It creates provisioning
change orders that it passes to the engine to get things done.
Buckminster should do something similar to that.
Thomas Hallgren
Re: P2 work on Buckminster [message #30941 is a reply to message #30908] Thu, 29 January 2009 08:19 Go to previous messageGo to next message
Well, that's a different story. And BM e.g. doesn't support generating
source features/bundles atm which is a show stopper for ECF. :-(
> > materializer?
Wow, that sounds like a lot of work. I guess it's a little bit more
complicated than the changes done to support p2 resolution?!
Do you have an estimate for when you plan to implement it?
Markus
Re: P2 work on Buckminster [message #30976 is a reply to message #30941] Thu, 29 January 2009 17:21 Go to previous messageGo to next message
I'm looking at it right now and it should not be overly complicated
actually. With a little luck, I'll have something for you within a day
or two.
Thomas Hallgren
Re: P2 work on Buckminster [message #31011 is a reply to message #30769] Fri, 30 January 2009 12:07 Go to previous messageGo to next message
Originally posted by: jconlon.apache.org
Hi Markus,
I too have seen error messages like these, but they were from the P2
Headless Director.
Have you figured out what caused your errors?
cheers,
John
>>> Sure, no problem.
>> project.
> [java] Provider
> materializing to
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> Markus
Re: P2 work on Buckminster [message #31046 is a reply to message #30838] Fri, 30 January 2009 13:23 Go to previous messageGo to next message
Hi Thomas,
Great to hear of your continuing work on P2izing BM. As a matter of fact
my task today was for me to revist a BM mashup (a cspec with an ant
actor) to create P2 metadata for a product, update site, and create
p2ized product artifacts. (I described it in the BM user newsgroup.)
news://news.eclipse.org:119/496345AF.0@tada
see inline for some questions...
> Hi Marcus,
Will the target platform materializer once P2'ized be able to create p2
enabled products from p2 repos?
It is the next part
Besides the eclipse.import reader, which will now read from p2ized sites
and the upcoming target platform materializer what else is planned?
How about the following functionality?
1. features -> p2 repo
I'm using the buildFileId: buckminster.pdetasks to do a build.site, and
org.eclipse.equinox.p2.metadata.generator.EclipseGenerator run from an
ant task to p2ize an update site. Will you be modifying
buckminster.pdetasks to do the p2izing?
2. product -> p2 repo
I'm also adding a product to a p2 repo. Today I, also do it with a
org.eclipse.equinox.p2.metadata.generator.EclipseGenerator wrapped in
an ant action. Are you planning to add this functionality as well?
I'm still coming up to speed on Buckminster, but what I have seen so far
I like.
Thanks for this great tool,
John
> Thomas Hallgren
>>>>> trunk?
>>>> Sure, no problem.
>>> project.
>> [java] Provider
>> materializing to
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> Markus
Re: P2 work on Buckminster [message #31081 is a reply to message #30558] Fri, 30 January 2009 16:58 Go to previous messageGo to next message
Hi Thomas,
Had a problem with this upgrade:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=263103
regards,
John
> of this).
> Thomas Hallgren
Re: P2 work on Buckminster [message #31285 is a reply to message #30976] Mon, 09 February 2009 12:09 Go to previous messageGo to next message
The latest version of Buckminster (available within the our from
updates-3.5) contains a new materializer with the id 'p2'. It is able to
install things found by the 'eclipse.import' reader into a target platform.
There is currently a limitation in that the artifacts must have been
found in a p2 repo, i.e. artifacts found on Orbit will not install. This
can be circumvented by using the normal targetMaterializer for such
components (by adding a matching mspec node).
Thomas Hallgren
> or two.
> Thomas Hallgren
Re: P2 work on Buckminster [message #31440 is a reply to message #31285] Tue, 10 February 2009 08:35 Go to previous messageGo to next message
> Thomas Hallgren
Hi Thomas,
thanks a lot. ECF build now uses p2 to materialize 3.5milestones/. :)
However, we still have a few issues.
- p2 materializes org.eclipse.ecf.* from 3.5milestones/. That should be
filtered out otherwise PDE build later uses the binary bundle as
dependencies instead CVS HEAD.
- CQUERY sets target* to "*" but only the current matching platform gets
materialized. This is probably owned to
org.eclipse.buckminster.core.materializer.P2Materializer.mat erialize(List <Resolution>,
MaterializationContext, IProgressMonitor) setting the p2 profile to
whatever comes out of the EnvironmentInfo service and not what is
specified in the CQUERY. Does p2 support wildcards anyway?
Markus
Re: P2 work on Buckminster [message #31476 is a reply to message #31440] Tue, 10 February 2009 08:50 Go to previous messageGo to next message
> Hi Thomas,
Not sure what the problem is here. If the binary bundle is superseded by
something with a newer version in your workspace (CVS HEAD), then surely
the build will use the latter. But perhaps I misunderstand the issue.
Can you please elaborate?
I'll have to check what happens. If they don't play funny tricks with
the OSGi filters, I should be able to pass a special object that
compares equal to everything. I'll provide a fix for this that you can
try out. I trust you're still able to test directly from our SVN HEAD?
Thomas Hallgren
Re: P2 work on Buckminster [message #31511 is a reply to message #31476] Tue, 10 February 2009 11:41 Go to previous messageGo to next message
PDE build appears to choose the binary bundle over sources (CVS HEAD).
That is, if I manually delete the binary bundles after materialization,
the build compiles fine.
However the underlying problem is, that the p2 materializer materializes
the binary bundles when it shouldn't. You can see the boms at
http://ecf2.osuosl.org/org.eclipse.ecf.tests.mspec.bom
Yep, I am. But only with Eclipse 3.5 used by ECF build. :)
Markus
Re: P2 work on Buckminster [message #31545 is a reply to message #31511] Tue, 10 February 2009 18:21 Go to previous message
Hi Markus,
I got some good tip from the p2-dev list today so I rewrote parts of the
P2Materializer. It is now inspired by the Repo2Runnable task (now
provided in Eclipse 3.5). In essence, the materializer no longer
performs a proper "install" into the platform. It bypasses that part
(all resolution is already made) and just executes the 'collect' phase.
That should get rid of the issue with platform filters etc.
The change is checked-in but not yet released. Feedback is very welcome.
Thomas Hallgren
> Thanks
> Markus
Previous Topic:SVN i18n considering a new release ?
Next Topic:Headless Build for Custom Builder
Current Time: Mon Oct 27 22:39:20 EDT 2025
Powered by FUDForum. Page generated in 0.13059 seconds
