Home » Eclipse Projects » Eclipse Platform » CVS merge problem
CVS merge problem [message #303939] Fri, 26 May 2006 09:14 Go to next message
Originally posted by: reh.tradingmetrics.com
I'm getting prompted for the other team member's password when
attempting to merge differences in CVS, using Eclipse.
We're using a CVS service provider.
Details:
Eclipse Platform
Version: 3.0.0
Build id: 200406251208
I did an update prior to commiting changes. As expected, in
'synchronize view' I had a list of files showing conflicts. Within
synchronize view, however, when I attempt to "Open in Compare
Editor" for any file listed, I am prompted for the other team
member's password.
The other team member has never used the computer I'm working on.
Anything obvious I'm missing, or should try?
Re: CVS merge problem [message #303952 is a reply to message #303939] Fri, 26 May 2006 10:22 Go to previous messageGo to next message
Richard,
Open the CVS Repository Explorer view (Window>Show Veiw>Other and
CVS/Repository Explorer) and see what user the location string contains.
If it is the wrong user then you can open the Properties from the
context menu and change the user name.
Michael
> Details:
> Eclipse Platform
> Version: 3.0.0
> member's password.
Re: CVS merge problem [message #303959 is a reply to message #303952] Fri, 26 May 2006 11:18 Go to previous messageGo to next message
Hi Michael,
Thank you. Here's what I see:
CVS/Repository Explorer shows two items. One for me, one for the
other team member (who, again, has not used this computer).
Would you suggest I discard his location, or update the properties
with my user name / password?
Best,
RH
Michael_Valenta@ca.ibm.com wrote...
> Richard,
> Michael
> > Details:
> > Eclipse Platform
> > Version: 3.0.0
> > member's password.
Re: CVS merge problem [message #303970 is a reply to message #303952] Fri, 26 May 2006 13:14 Go to previous message
> Richard,
Actually, Michael, this didn't take. CVS Repository Explorer showed
two trees (one for the other team member, one for me) and as I
changed the properties that his tree 'disappeared'.
Then when I would try 'Open in Compare Editor' I would get the same
password prompt.
Thanks for your input. I'm not sure if it's an problem, or just my
needing to RTF Eclipse manual, but I discarded my changes and re-
entered them just so I could move forward.
RH
> Michael
> > Details:
> > Eclipse Platform
> > Version: 3.0.0
> > member's password.
Previous Topic:How to import Swing app to VE?
Next Topic:Marker not displayed on correct line
Current Time: Sun Aug 31 18:27:11 EDT 2025
Powered by FUDForum. Page generated in 0.03509 seconds
