| STEM Build Mac OS [message #2624] | Sun, 26 April 2009 15:52  |  |
| Eclipse User  |  |  |  |  | Hi again :),
 Trying to launch the 0.5.0.I20090423 STEM app from my Mac Pro, I get:
 !ENTRY org.eclipse.osgi 4 0 2009-04-26 12:44:07.581
 !MESSAGE Application error
 !STACK 1
 java.lang.IllegalStateException: Unable to acquire application service.
 Ensure that the org.eclipse.core.runtime bundle is resolved and started
 (see config.ini).
 org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
 org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
 sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
 java.lang.reflect.Method.invoke(Method.java:585)
 at  org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
 I'm thinking that this might have something to do with my 1.6 VM not
 playing nicely with Carbon. I've been using the Cocoa x86 builds for my
 own environment. Anyone had any similar issues?
| Re: STEM Build Mac OS [message #2654 is a reply to message #2624] | Mon, 27 April 2009 09:56  |  |
| Eclipse User  |  |  |  |  | Originally posted by: daford.almaden.ibm.com.invalid
 Miles,
 I have almost the exact set up as you, Mac Pro, latest from CVS and a 1.6
 JVM, and I have no build or execute issues at all.  Everything works as
 expected.
 Something must be different between our setups.  I'm running 3.5M6.
 Dan
 Miles Parker wrote:
 > Hi again :),
 > !STACK 1
 > (see config.ini).
 >     at
 pLauncher.java:74)
 >     at
 >     at
 >     at
 >     at
 >     at
 ..java:25)
 >     at
| Re: STEM Build Mac OS [message #560932 is a reply to message #2624] | Mon, 27 April 2009 09:56  |  |
| Eclipse User  |  |  |  |  | Miles, I have almost the exact set up as you, Mac Pro, latest from CVS and a 1.6
 expected.
 Dan
 Miles Parker wrote:
 > Hi again :),
 > !STACK 1
 > (see config.ini).
 >     at
 pLauncher.java:74)
 >     at
 >     at
 >     at
 >     at
 >     at
 ..java:25)
 >     at
FUDForum. Page generated in 0.03945 seconds
