Home » Eclipse Projects » Eclipse Platform » When I start a Ant target, Eclipse starts building
When I start a Ant target, Eclipse starts building [message #303403] Mon, 15 May 2006 08:20 Go to next message
Originally posted by: agent.smith.matrix.com
------=_NextPart_000_0006_01C6782A.AABD9AB0
Content-Type: text/plain;
charset="iso-8859-1"
Lets assume a simple Ant target which just does an echo.
If I start that Ant target from within Eclipse, Eclipse starts building =
all my projects, which takes much time since they are big projects.
Automatical Building is turned off. Nevertheless Eclipse starts building =
when I start an Ant target from within Eclipse, no matter what kind of =
target.
I use Eclipse 3.0.1, but soon we will migrate to Eclipse 3.1.2.
Any ideas?
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2873" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Lets assume a simple Ant target which =
just does an=20
echo.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>If I start that Ant target from within =
Eclipse,=20
Eclipse starts building all my projects, which takes much time since =
they are=20
big projects.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Automatical Building is turned off. =
Nevertheless=20
Eclipse starts building when I start an Ant target from within Eclipse, =
no=20
matter what kind of target.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I use Eclipse 3.0.1, but soon we will =
migrate to=20
Eclipse 3.1.2.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Any ideas?</FONT></DIV></BODY></HTML>
------=_NextPart_000_0006_01C6782A.AABD9AB0--
Re: When I start a Ant target, Eclipse starts building [message #303432 is a reply to message #303403] Mon, 15 May 2006 12:53 Go to previous messageGo to next message
> target.
> Any ideas?
In the Launch Configuration for your Ant script, you can configure a
"Build before launch" option. It is on the Build tab of the Launch
Configuration edit dialog.
Hope this helps,
Eric
Re: When I start a Ant target, Eclipse starts building [message #303458 is a reply to message #303432] Tue, 16 May 2006 02:02 Go to previous message
Thank you. I will test it.
"Eric Rizzo" <eclipse4@rizzoweb.com> schrieb im Newsbeitrag
news:e4abmc$4c6$1@utils.eclipse.org...
>> target.
>> Any ideas?
> Hope this helps,
> Eric
Previous Topic:Eclipse crashes while working on Suse Linux 9.3
Next Topic:Trapping Closing Event of a ViewPart
Current Time: Fri Oct 31 22:36:47 EDT 2025
Powered by FUDForum. Page generated in 0.14919 seconds
