Home » Eclipse Projects » Eclipse Platform » Checkstyle - What do I need to do to get error indicators to update when I save?
Checkstyle - What do I need to do to get error indicators to update when I save? [message #302816] Sat, 29 April 2006 14:49 Go to next message
Originally posted by: timblanchard.shaw.ca
What do I need to do to get error indicators to update when I save? I enable
checkstyle for a project, open a source file, the checkstyle errors are
shown, I fix an error and save, but the error indicator does not go away.
The error indicators will be updated if I disable checkstyle for the
project, then re-enable it or if I rebuild the project, but that is time
consuming.
Eclipse version is 3.1.1. Checkstyle plugin is 4.0.92. I'm having the same
issue with other combinations, though. OS is Windows 2000, SP4.
Incidentally, I set this up on Windows 2003 Server and the plugin works
fine. Someone at work is using the same plugin, on Windows XP and it works
fine. But upgrading to XP is not an option.
Re: Checkstyle - What do I need to do to get error indicators to update when I save? [message #302826 is a reply to message #302816] Sat, 29 April 2006 16:42 Go to previous message
"Tim B" <timblanchard@shaw.ca> wrote in message
news:e30cig$k7b$1@utils.eclipse.org...
enable
> consuming.
same
Never mind - for some reason, the workspace was not configured to build
automatically. Changing that fixed the problem.
Previous Topic:Launch Menu
Next Topic:Custom PropertySheet for Properties View
Current Time: Sat Jul 26 10:02:45 EDT 2025
Powered by FUDForum. Page generated in 0.05967 seconds
