Home » Eclipse Projects » Eclipse Platform » Plugin Extension Point
Plugin Extension Point [message #302647] Wed, 26 April 2006 08:08 Go to next message
I have two plugin projects. Both are standalone working. My first plugin
has one functioality (a search) which I want to use in my II plugin. Now,
I dont want to re-invent the wheel and therefore want some mechanism by
which I can make my II plugin interact with I plugin.
Is there a way I can send data from II plugin to I plugin and invoke some
of its method and a View class?
Any response is appreciated
tia
~Mohit
Re: Plugin Extension Point [message #302648 is a reply to message #302647] Wed, 26 April 2006 09:37 Go to previous messageGo to next message
From the sounds of it, you could just import Plugin I into Plugin II.
open Plugin II's plugin.xml file, click on its "dependencies" tab and
add Plugin I to the list there.
You should then have access to Plugin I's public classes, just as you
have access to Plugin II's classes.
Kevin.
Mohit wrote:
> Now, I dont want to re-invent the wheel and therefore want some
> mechanism by which I can make my II plugin interact with I plugin.
> some of its method and a View class?
> tia
> ~Mohit
Re: Plugin Extension Point [message #302651 is a reply to message #302647] Wed, 26 April 2006 09:53 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
If plugin I exports as API a method on a class within a package, then
plugin II can just call it, assuming plugin II made plugin I a pre-req.
Mohit wrote:
> tia
> ~Mohit
Rich Kulp
Re: Plugin Extension Point [message #302676 is a reply to message #302651] Thu, 27 April 2006 07:17 Go to previous messageGo to next message
Thats precisely what I was planning, and I guess the way to do this is
through extension point. However, the problem is I dont know anything
about Exntension points neither could I find any lucid article/ example on
net.
~Mohit
> Mohit wrote:
>> tia
>> ~Mohit
Re: Plugin Extension Point [message #302679 is a reply to message #302647] Thu, 27 April 2006 08:00 Go to previous messageGo to next message
You can always use the selection service to communicate between plugins:
http://www.eclipse.org/articles/Article-WorkbenchSelections/ article.html
Other than that, you can use IWorkbenchPage#findView(*) from one view to
find the other view and then cast the found view to call methods on it.
Later,
PW
Re: Plugin Extension Point [message #303018 is a reply to message #302676] Fri, 05 May 2006 11:39 Go to previous message
See
http://www.eclipse.org/articles/Article-Plug-in-architecture /plugin_architecture.html
Rich Kulp
Previous Topic:Keep ant association with "build.xml"
Next Topic:WorkspaceRoot project cache
Current Time: Sat Nov 08 20:29:59 EST 2025
Powered by FUDForum. Page generated in 0.03904 seconds
