Home » Eclipse Projects » Eclipse Platform » importing from existing source without moving original files
importing from existing source without moving original files [message #301097] Thu, 23 March 2006 13:22
Originally posted by: mandiv.corp.untd.com
I have something checked out using unix in my H:\ drive.
I want to be able to use Eclipse as IDE for it.
But, I don't want to do a cvs checkout in Eclipse (due to some reasons).
How can I import my files from H:\ drive so that they are available in
eclipse and at the same time Eclipse does not copy them from H:\ drive to
the workspace - because in that case if I edit the files the changes won't
be available in H:\ drive and I would need to move them manually.
I am not working on any Java Files. It's more of a Web Project with
html/css/js files and I want to use the plugins for editing js files
primarily.
Please let me know.
Thank you,
Mandy
Previous Topic:Adding Menu Items to Menu's
Next Topic:Plug-in Project Problems
Current Time: Fri Oct 31 02:09:38 EDT 2025
Powered by FUDForum. Page generated in 0.45934 seconds
