Home » Eclipse Projects » Eclipse Platform » Package Explorer
Package Explorer [message #300962] Tue, 21 March 2006 03:01 Go to next message
Originally posted by: john.watson.yahoo.com
Hi All,
I have to create a view similar to Package Explorer. The difference is
that my view should show some files and hide other files depending on file
extension. Is it possible to be configured the Package Explorer in this
way or I should extend it? Which the extension point and class for Package
Explorer?
John
Re: Package Explorer [message #300986 is a reply to message #300962] Tue, 21 March 2006 10:09 Go to previous messageGo to next message
If you add the extension to your plugin.xml (in this case
org.eclipse.ui.views), you can use "Find declaring extension point" to
find the extension point in the Search view, and then right click on it
and use "References" to get the list of extensions that reference this
extension point. Then you can find out the id and class that implements
the Package Explorer.
but you may or may not be able to use it (it might be internal).
Also, consider the common navigator in 3.2M5 ... it's specifically
designed to provide Resource Navigator-type view without being tied to
the IDE or JDT.
Later,
PW
Re: Package Explorer [message #301013 is a reply to message #300986] Wed, 22 March 2006 03:06 Go to previous messageGo to next message
Hi Paul,
you mean "Experimental Resource Navigator? It is available in 3.2M3. It is
very onteresting for me. What are the Eclipse team plans for it? Will it
be included in final version of 3.2? Where Can i get more information how
I can use it?
John
> the IDE or JDT.
> Later,
> PW
Re: Package Explorer [message #301026 is a reply to message #301013] Wed, 22 March 2006 07:56 Go to previous messageGo to next message
John Watson wrote:
> Hi Paul,
> is very onteresting for me. What are the Eclipse team plans for it? Will
> it be included in final version of 3.2? Where Can i get more information
> how I can use it?
Unfortunately, I'm not sure where more information on the Common
Navigator is, but it's looking pretty good in 3.2M5 and the soon to be
out 3.2M6, and I've been told WTP is going to use it in there 3.2 based
offering ... but that's not confirmed.
Later,
PW
Re: Package Explorer [message #301045 is a reply to message #301026] Wed, 22 March 2006 10:34 Go to previous messageGo to next message
Hi Paul,
I found that the built-in filter in Package Explorer works pretty well for
me. I just need a way how to set the filter of Package Explorer
programatically.
John
Re: Package Explorer [message #301061 is a reply to message #301045] Wed, 22 March 2006 15:37 Go to previous message
Originally posted by: varavamu.yahoo.com
try looking at:
org.eclipse.ui.ide.resourceFilters
org.eclipse.jdt.ui.javaElementFilters
hth,
Vijay
John Watson wrote:
> Hi Paul,
> for me. I just need a way how to set the filter of Package Explorer
> programatically.
> John
Previous Topic:Seperating project files
Next Topic:Callisto Language Packs
Current Time: Thu Sep 04 15:21:15 EDT 2025
Powered by FUDForum. Page generated in 0.04751 seconds
